W
WBubel - 2010
Where can I get help in Identifing Critical Components for Incoming Inspection?
From your risk management file .... safety critical components, performance critical components, regulatory related components, and other outsourced parts which needs a validated process.Where can I get help in Identifing Critical Components for Incoming Inspection?
In Incoming Inspection we are trying to Identify Critical components.
1. Is it components that could lead to the reduction in performance of the final device?
2. Is it components that could lead to the stopping or or slowing of the production line?
3. All active Components. ie transistors, diodes, Integrated Circuits, transformers.
4. All passive components. ie resistors, capacitors, inductors, brackets, knobs, switches.
5. All components big or small. :mg:
Yes and it depends!
• What are the risks associated with your product/production?
• Are you in a regulated industry, how do the regulations define critical component?
• Do any of the parts you received effect the Safety and/or efficacy of the final product?
Phil
If you´re talking about safety-related componentes (as some ot the others suggested) you could use clause 4.8 "Components of ME EQUIPMENT" in IEC 60601-1. Basically, any component the failure of which could result in a hazardous situation are considered critical. There´s another situation, when a fault in a component could generate unnaceptable risk, the component has to be what the standard call a COMPONENT WITH HIGH-INTEGRITY CHARACTERISTICS in ME EQUIPMENT. This is a special kind of critical component.
There are some..nuances..in the way to define these components because it has to be arisk-based decision.
