During Management Review Meetings, as the MR of my firm, I generally present an analysis of the last internal audit findings (in ppt).
I have done this clause-wise (no. of findings against each clause of the ISO 9001 standard), against the organization procedures (number of findings against each procedure), repeated NCs in key areas (across multiple internal audits), Pareto analysis of findings against key areas, etc. How do you do this to make it more effective?
It would be great to get inputs from this forum on any other ways you have done and presented audit findings in your organization, which you found more effective to make managers act.
By the way I am working in an IT product and services company.
Thanks in advance for your valuable inputs.
Although I have no objection to doing what you do, it is way beyond the requirements of the standard.
I would ask if there is sufficient benefit for the level of effort.
The requirement is simply to discuss the results of audits. I might add, that it is all audits, not just internal audits. If you are not discussing CB and customer audit results you are not meeting the requirement.
I may have a slightly different perspective about management review, and I'm sure that perspective drives my approach. I think that management review is comprised of two main components. Determining the state of the quality management system and then determining where you want to go with that insight.
Determining the state of the system is accomplished by discussing the items listed in element 5.6.2 a-f.
results of audits
customer feedback
process performance and product conformity
status of preventive and corrective actions
follow-up actions from previous management reviews
changes that could affect the quality management system
More can be discussed if appropriate, after all, 5.6.1 says that you need to discuss the quality policy and quality objectives to confirm they are still relevant. Three out of four topics from analysis of data (8.4) are included in the above list (customer feedback, process performance and product conformity), so discussing the results of all the KPI are appropriate.
After good discussion, the awareness level of all participants is raised concerning the state of the system.
At that point you are ready for 5.6.2 g recommendations for improvement.
These improvements are expressed as shown in 5.6.3 a-b
improvement of the effectiveness of the quality system
improvement of product related to customer requirements
These improvements can be expressed as action items -- action items to be discussed at the next management review (5.6.2 e).
There also needs to be consideration for resources needed to accomplish the improvements. (5.6.3 c).
I see more benefit to this approach than I do to an overly detailed report on the internal audit. Others may have different opinions.
