One the the minor findings noted by my registrar auditor was that incomming test reports/certifications for raw material were not being reviewed to ensure results are acceptable per applicable specifications. Ref AS9100 Para 7.4.3.
We always check to see if the correct specification and material description is called out on the cert. We also send out a material sample for testing to an independent lab every tenth receival.
Do I really have to verify the chemicals and physicals recorded on the cert against the spec for every raw material receipt?
Jim
Jim
