A company I know received a nonconformance on 9.2.2.
The auditor stated you cannot have the same internal auditor perform all your internal audits.
Company has had the same internal auditor for 2019 & 2020.
The company's own internal audit paperwork is used and they create the audit schedule to ensure objectivity and impartiality.
In my opinion the NC is bogus and based on the opinion of the auditor and not the requirement due to the following:
-The internal auditor is outsourced externally.
-The internal audit is conducted using the company's own internal audit paperwork identifying the clauses to be audited.
-The internal auditors position is to make sure the company meets the requirements of a-f of 9.2.2
-The internal auditor does not have the responsibility of any of the requirements in a - f of 9.2.2 therefore they did not audit their own work.
-The internal auditor does not own or manage the internal audit process. She is only executing it as defined by the company she is doing the audit for. She is not auditing her own work. If this NC were in fact true, none could only have a single internal auditor and that means thousands of companies would be nonconforming.
Nowhere in the standard does it say you must have more than one auditor.
The below is what is actually written on the NCR.
Applicable 9100/9110/9120 requirement/clause: 9.2.2
Process/Area/Department Internal Audits
Classification (Ma/Mi): Mi
Statement of Nonconformity: The selection of auditors and conduct of audits to ensure objectivity and impartiality of the audit process is not always effective.
Objective Evidence: The Internal Audit Schedule Rev. F dated 04-01-18 for 2019 only has one auditor assigned to perform all of the internal audits.
The auditor stated that you have to have someone else that audits the internal auditors work. Wouldn't this be the external auditor if this is the case?
All previous external audits have not mentioned any issue with this.
Thank you in advance for your comments.
