abdelouahed
Hi all ,
Please i need your help regarding an issue with %AV in GRR studies, I'm using a Software to calculate the MSA result but in almost cases the result of the %AV is equal 0.
so in the last IATF audit the auditor ask me to explain why the %AV=0 because statistically is illogical.
Is there someone who can give me the reason why ? also if you have a excel sheet that can i use to compare the results between the software and the sheet.
I have try with the GRR example in the MSA manual and the result was the same ( manual vs software ).
Thank you.
Thank you.
