Paul Simpson
Replies always welcome
Cripes, when I asked for feedback I didn't expect both barrels.
Two benefitsPeter Fraser said:Paul
Dare I ask... what do you see as the benefit of this sort of diagram? Why do you think that people produce them? Is it so that (i) employees can learn something about the organisation they didn't know before, (ii) it will help staff do their job better, or (iii) they can meet some (unexplained) requirement in ISO9001:2000?
- It can help the top management understand ISO 9001 is about business processes - not just document control
- It identifies the processes that run across the business - not departmental procedures - helps to change the perspective
Depends how you quantify value add. Generally the thinking that happens way before adds the value - the "picture" just provides evidence of the outcome.Peter Fraser said:How many such pictures have you seen which add value to an organisation?
I have heard them called a wide range of things - I really don't mind what they are called.Peter Fraser said:Just picking up a few points from your example (but similar comments could equally be applied to the vast majority of such maps - by the way, is it better to describe them as "system maps" rather than as "process maps", which as you know I think of as a flowchart of a process?)
My loop is a bit wider (for simplicity) to show that it goes through a management review and then may lead to the need for resources before it comes back to the core process - but I take your point, there has to be appropriate feedback to the process.Peter Fraser said:1 "Monitoring & Measuring" is often done as an intrinsic part of another process rather than as a separate process. Even if it is a separate process, it will (or should) affect the process(es) being monitored (otherwise why do it?) - so there should be an arrow going up as well.
Again the same logic applies - the Business Planning process should preplan these activities and any monitoring and measuring of Research and Development and Planning and Logistics would be part of a feedback loopPeter Fraser said:2 In the same way, "Research and Development" and "Planning and Logistics" may well have an impact on the "Provision of Resources", so there is another arrow or two needed.
The aim was that the Business Planning activity is a separate (managerial) process and would identify the need for all resources. I take the point - on Revision 2 I will have another box!Peter Fraser said:3 "Provision of Resources" may impact on "Monitoring & Measuring", so another arrow is needed.
Again monitoring and measuring will tell you this and feedback to the other processesPeter Fraser said:4 "Fulfilling repeat orders" may affect "Enquiry and Order receipt" if the production line can't cope and you have to quote longer delivery times...
Not sure I can agree the links are missing - as with all process interrelationships they have to be explained by the person who developed them (as we can see in this thread!). I understand about complexity - hence all my interrelationship diagrams start off simple and stay that way - constructive feedback notwithstanding.Peter Fraser said:My concern is that at the one extreme the system map will have the sort of missing links I mention above, and at the other you will need an n-dimensional picture which is so complex that it would be unusable. I personally don't see any benefit in either, other than just to satisfy an external assessor, which cannot be a good reason for doing it.
Not sure I understand the argument here. Yes, all the processes are operating at the same time but - for one customer and one order - they are happening in a logical sequence. There is an argument you don't need managers on processes that are running effectively - hence the earlier efforts to delayer and process re-engineer. Whether you consider either to be a success I will leave to the individual!Peter Fraser said:In any organisation, "process interaction" is far more involved than this sort of picture can show in any sort of accurate and usable format, and the "sequence of processes" as it is usually depicted makes no reference to the fact that many instances of each process may be happening at the same time. If everything was linear, you probably wouldn't need managers, and certainly not managers who understand what is required for good process management.
Each to his / her own. Your system sounds pretty good to me - if only you weren't charging me so much to evaluate it I might be even more positive. But seriously whatever works, works. From an assessment point of view I would accept any style of addressing the standard element that the organization puts in front of me. .....Does that make me enlightened?Peter Fraser said:An alternative approach? Our customers use a simple numbering system to define a small number of process groups ("2 Getting Work", "3 Doing Work" etc), and processes with each (eg "2-1 Respond to an Enquiry", "2-2 Prepare a Tender") which implies a logical sequence, and define the processes (using "process maps"!) which link to other processes from the relevant tasks. They only draw a picture if they have an unenlightend assessor.
Always grateful for your input, Peter.Peter Fraser said:So ... grateful or not?!
