Re: Cpk Calculation
I would clarify this a bit:
1) confirm that you have a capable measurement system for this characteristic (GRR at 5% of tolerance or 10% of control limit for 1.66, minimum, 7% of tolerance or 10% of control limit for 1.33 minimum)
2) run a process trial to understand the variability of this characteristic
3) confirm stability, correct distribution (normal only if it is a normal process - if it is normal and it should be non-normal, then you may have too much measurement error, etc.), remove outliers if identifiable as special causes
4) calculate the standard deviation (if a normal distribution or similar - not necessary for uniform distribution)
5) calculate what dimension tolerance you should have if Cpk had to be 1.33 or 1.67 based on the appropriate statistics for the distribution
3) confirm stability, normality, remove outliers
