CMfgT
Not sure if this is the right area to post this question, but our facility makes a number of cylindrical pins and shafts with I.D. Threads. After we tap the threads many parts will be induction heat treated or welded in an assembly. A number of times we will shrink the threads with the heat being applied and the threads will not gage. This will result in a rework op to retap and gage. Then we run into the issue of the no go going after being retapped. Does any one have a better solution to this.
All I see is we can do two things:
1.Drill and tap after Heat Treat or weld, but the parts will be to hard and break taps, or the weldment will be difficult to fixture to tap threads.
2. Plug the hole with a bolt or some material to keep the I.D. Hole from sucking the heat towards it and shrinking.
#2 is what I was hoping to hear some success with. I just don't want to get a bunch of bolts stuck in the I.D. It seems like we have the worst luck with 1/8-27 NPSF threads.
Sorry for the ramble, just a big quality / waste for us and would like to at least see if others are experiencing the same problem.
Thanks,
Thanks,
