I have a question regarding implementing design history/technical documents in the QMS. Technical documents are implemented through the engineering change order process. All stakeholders first sign off on the Engineering Change Order to approve the engineering changes (mostly from the engineering team). The documents have not been implemented in the QMS yet. The updated engineering documents then must be implemented in the QMS at which point there is change request form to complete with space for signature approvals. My question is, do the set of people who first approved the ECO changes also sign the change request form to implement these documents in the QMS? That creates a lot of signatures. If anyone has a simplified system for implementing technical documents, I look forward to your response.
Thanks.
Thanks.
