W
WannaDoQA
Hello all. I'm relatively new to the forum but have been reading for a while. I can't find help anywhere else as I'm also relatively new to the field of quality management and ISO but am on my own to try to get some of these things figured out, so please bear with me.
We are a small wire harness manufacturing company, just to give some background. We buy connectors, terminals, and wire/cable and put it all together according to customer specifications. We maintain product traceability through internal Lot numbers.
We were recently audited by one of our customers and they had many findings resulting in issuing many Supplier Corrective Actions. We are not ISO certified but we are still trying to comply with ISO (and we said as such), thus we were audited to ISO 9001:2008. We had many ISO procedures in place from 1994 but were struggling trying to get up to speed with 2008. So, ultimately, it turned out not so good for us.
One of the findings was related to our Purchasing procedure, that parts are not being inspected but are certified on the C of C for products they buy from us, and that there is no evidence the parts can be traceable to the original manufacturer and material specification.
For example, for product 12345, we may have a customer requested C of C that states the certification of specific attributes of a specific component, such as, "Component Part# ABC, manufacturer Schurter, rated 250V, 10Amp, UL and/or CSA marked."
We will send that C of C with the completed product. The short of it is that we are stating those things on our C of C but we are not actually inspecting the part to see if it meets those criteria - I can fix that and I think I did. However, we are not able to trace that part back to its original manufacturer/material spec, and that's what I need help with.
Here is what I've done so far:
1: Created Incoming Inspection procedure that doubles as a record for each component that requires certification. It lists the attributes/criteria that we certify on the C of C. We check off that we verified those attributes, enter data specific to the delivery (date, supplier, lot or PO#, quantity inspected) on the document itself, print out the paper and sign/date it. This document is then filed. We do this for every part that requires certification.
2: Added each part that requires certification to our Incoming Inspection List, which does not allow parts to be received until they have been inspected.
What I need to do:
-Come up with a way to trace certified components throughout production. Right now, even if I have the record of the part's certification, I cannot trace it to a specific Lot that we build. When we release an internal Lot to begin production and start pulling parts, we do not record any information related to the component anywhere - we simply use FIFO. If our customer calls me and asks me:
"Hi WannaDoQA, I have product 12345 that you built, Lot# XYZ, which uses a certified component Part# ABC. Can you provide objective evidence that component ABC was certified and used in product 12345 for Lot# XYZ?"
My answer to this is: No.
I can show them the record of certification for the component, but I cannot say whether it was used in Lot XYZ.
It seems like a super long post for such a short question but does anyone anywhere know how I can do this easily, for really cheap, and really really fast? I'm ready to answer any questions because I know it all seems so convoluted.
How do other companies do this? I'm assuming it's a really easy fix, and believe me, I have my palm ready to hit my forehead but.........
Help!
What I need to do:
Help!
