NDesouza
Hi NDesouza,
Sounds like you're in quite the pickle.
Is it not up to your organisation to approve the progression and closure of SCARs? In my experience, the supplier develops an action plan, provides a root cause analysis and suggests a CAPA plan, and each of these stages could be subject to the organisation's approval.
Ultimately, it would be up to the organisation to accept or reject the outcome of a SCAR so if you have determined that the supplier's root cause and CAPA plan are not robust enough, you should reject this.
Lots of good points raised by other posters here; how does your organisation handle poorly performing suppliers?
Thanks for your response,
I am a 3rd party brought on as part of a supplier management solution the customer. I don't actually work for either side directly. When the customer doesn't approve of the RCCA, they inform the supplier and myself. Together me and the supplier work to improve this. I have implemented a feedback loop to keep the supplier from submitting poorly written RCCAs. When they follow the plan, it works very well. The problem is that submitting poor RCCAs isn't the only problem internally for these suppliers.
