Well, yes...not knowing how to use a tool is the biggest problem - even in problem solving and SPC. And doing things to check a box is pathetic.
But...
When properly applied (and at this point I won't get into Dr. Wheeler's approach. It is statistically more accurate, but I believe you get adequate signals from the AIAG approach for most practitioners) there is some value.
The reason why we do most things in quality is to answer two questions:
1. How do you know?
2. How can you prove it?
In order to make you claim that parts are so similar that your process has no variation:
1. How do you know? You would have had to measure them with a device so accurate that its gage error did not make the difference between the parts!
2. How can you prove it? Well, if you have another methodology the folds intrinsic gage error (repeatability) and operator effect (repeatability) to show what you are seeing is statistically similar...now is the time to discuss it.
Even if you process doesn't show variation today (If my variation is truly that low, then I probably don't even need to do SPC on that characteristic, so NDC would be essentially irrelevant anyway):
1. How do you know it won't tomorrow? Are you claiming it is impossible for a special cause to occur? No wear or material variation will ever be significant? Nothing will break? Going to let your customer be the detection? Also, some process will vary, but very slowly, such as stamping dies. It may take 3 years - which day to day will be minuscule. Yet - you want to watch it to predict when to pull the die. It's just the charting frequency can be very low.
2. How do you prove it? If you have no clues that your gage is giving you adequate statistical resolution, you really haven't proven your point.
As far as having no better measurement system available- it may actually be fine if calculated correctly or you need to understand the gage limitation and discuss that your measurement capability can't detect process changes well with your customer.
"I have heard of people who intentionally machine samples for gage R&R to induce variation into the study so they can elevate their NDC just to pass the customer requirements." OK..I get it is for customer requirements if you do not understand the tool, but what you are really doing is making variation that is likely to occur over time that has not yet occurred. Totally legitimate. It is even legitimate to use parts slightly out of specification - as long as you use historical or historical estimate of process variation in the calculation, not the variation of the parts presented to the study.
Yes..one of the biggest problems of Gage R&R is it wants to know the variation of your process over time, you simply do not have it yet if it is a new process, your current studies won't determine it...it is a real struggle. That is why I use the estimate of the process variation over time assuming it will be a capable process - or about 75% of the tolerance. It is an estimate - but probably far more reliable, or at least reasonable, than any other projection of the process over time.
I used to think exactly the way you did in your post. But a little more thought, and corrections of calculations, started to make a lot more sense. Will the result be so accurate you can carve them into stone tablets and bring them down from the mountain? No, but it can help justify your gage choice and prevent you from having the common error of a gage - and incorrect usage of the gage - masking your true process variation.
