Excel files for DOE (Design of Experiments)
Re: DOE - Design of Experiments - Shainin
Try the search function in the blue menu bar above. I have seen 1 or 2 DOE files in Excel in this forum, but they are very limited to a few basic full factorial designs. DOEs by nature are highly variable in structure, so you will not find much in the way of an Excel file. You really need specialized software.
I
Ingo1966
Re: Excel files for DOE?
I use MiniTab for DoE Calculation. But in my Training Classes I also show some Excel Files which give the Participant a better picture how these Test Matrices can be analysed.
Hope it helps
I
Ingo1966
I have forgotten to attache an Excel Example.
Here is one Example of a D-Optimal 3 Factors on 3 Level in 15 runs with simulated data's.
I have other DoE Excel Examples for teaching purposes:
If someone is intrested don't hesitate to contact me.
My Excel Files are free for use.
Standard Yates L8 --> 3 Factors and 4 Factors
Simple L9 --> 2 Factors on 3 Level
CCD --> 3 Factors 3 level in 15 runs
Box Behnken Design --> 4 Factors 3 Level in 27 runs
  • D_Optimal.xls
Q
Quentos
Re: Excel files for DOE (Design of Experiments)?
My Name is quentos, am really ineterested in some of your Excel Add-in for design of Experiment data Analysis and planning.
Wishing u a speedy recovery from your eye surgery.
Quentos
shiv47
Can You share DoE Templates for easy use in Excel?
1. Standard Yates L8 --> 3 Factors and 4 Factors
2. Simple L9 --> 2 Factors on 3 Level
3. CCD --> 3 Factors 3 level in 15 runs
4. Box Behnken Design --> 4 Factors 3 Level in 27 runs
I
Ingo1966
attached some Excel DoE but I strongly recommend statistical Software for application. The Excel Files are only for teaching purposes.
  • Box_Behnken_V2.xls
  • Central Composite.xls
  • L8_4Factors.xls
