Process Mapping - Process Flow and Interactions of Processes - ISO 9001
michelle8075
Here I go again with another question.....
I am working on the process flow for ISO-9001:2000 and I just want to make sure I am doing this correctly. Something tells me that I am not....
My process map is not very detailed at all. We determined that all our "detailed" processes are actually our procedures. So why have them in two places (I can probably call out each procedure next to each process in the map, but I have not done that yet.
Our rough draft process map shows the customer giving us the order, us processing the order (not any detail there, literly it says "Receive Requirements from Customer via quote request, Sales w/ Mgmt perform contract review"). Then the map goes into basic Project Management, then Mech / Controls Design, etc.
Can a process map be this simple? We also have an old Process map the quality personnel before me did that is 36 pages long in VISIO. I think that is too detailed.
Looking on the cove I have seen every extreme. I guess, I am asking if just showing the "bare bones" process an order goes through our company, is that enough?
Everyone here has already provided me with valueable input on some other items I have going on. I appreciate it all! One day I am hoping to get to that Guru status :) too..... for now, I just need some solid help. :nopity:
cncmarine
are you doing a process map for Lean or trying to fulfill requirements for Interrelation of Processes
cncmarine
If its for the interelation of processes then you are doing it correct
Marc
Fully vaccinated are you?
Attach an example and some folks here will take a look at it. Print it out as a pdf or gif file or something. Some folks may have Visio - I don't and can't remember if SmartDraw will open Visio files.
michelle8075
I am doing it for 9K2K, where it says "The organization shall establish , document, implement and maintain a quality management system and continually improve its effectiveness in accordance with the requirements of this International standard. The organization shall b) determine the sequence and interaction of these processes".
I don't have in my process map anything about continuous improvement, Management Commitment, Measuring & monitoring... Control of Customer product, nonconforming material......
So, I just have the "bare bones" of what our company does. But I figured all my procedures covered the above items.
I just have a feeling I am way off... Don't have much help here at my job. :thanx:
michelle8075
I pulled the VISIO Document into word. (Let me know if anyone is having a hard time opening this one.) I hope that this works! Please note that this is a VERY ROUGH Draft. I know that it does not follow much of any kind of set-up. It was us just getting our ideas out.
Thanks again for everyone's help! :agree1:
  • Process Map 1-24-05.doc
BadgerMan
I don’t think you can have too many flow charts, but they can be too big and/or too detailed. Having several different flow charts with different levels of detail is the method we chose. Our QM has a high-level flow chart, like you’ve described, that references our procedures. Then, many of our procedures contain more detailed flow charts.
Your approach sounds like a good one and the idea of listing the procedure within the process symbol would be very helpful for someone trying to learn about your system. If you have an electronic system, try hyper-linking from the flow chart symbols to the related procedures or other flow charts.
K
KimLoree
I may have over-simpified...but here's what I did to meet the requirement (attached). I simply copied the process model out of the standard and placed our tier one document numbers in each section of the model.
I then placed the model in our Quality Manual, in a section titled "Process Relationships". I further supported it with a matrix that showed each document's relationship to the standard. Nothing wrong with the way you are doing it that I can see. Just another idea.
  • All Process Flow.ppt
G
Greg B
Kimloree,
Welcome to the cove. This is an excellent idea and everyone could achieve it for their document map but does it truly show the processes?
