L
Laser
We seem to have a re-occuring problem of missing weld nuts or similar. What are some suggestions on ensuring that this problem go away?
Any suggestions would be appreciated.
Problem as in falling off or as in didn't weld in first place? Manual operation?
I'll assume forgotten and welded manually-
If you are manually welding you could go to robotic. Maybe not feasible...
If you are doing short runs you could count out the number of weld studs/nuts that are required and give the operator that exact amount. If you have leftovers or not enough then you know you have an issue.
Short runs of 100-1000 parts with 8- 30 weld nuts/fasteners per unit.
I see. That's quite a few welds per part. I think this is a pretty common problem.
Are all welds done consecutively at the same setup?
I've heard of having welders sign of each weld they did on a weld print that travels with the part. I'm not a big fan of this but some action may be better than no action. For example, if one welder does 8 welds at one setup then someone does another 4 welds at a different setup, have them each sign off on a copy of a weld print that that lot of 10, 25, 100 parts are good. Collect sign-offs at end, keep as a record.
I think the more information you can provide on your process the more help you'll recieve from other members.
We are a contract manufacturer, we weld on several different weld nuts and fasteners per customer specs, however, we seem to have a recurring issue with missing weld nuts/fasteners. Some parts have several weld nuts/studs on them, some only one, obviously the parts with only one feature needing welding are never missed, however sometimes with multiple weld nuts/fasteners we struggle. Any additional advice would be appreciated.
Thank you.
I can sympathize as the company I use to work for also did a lot of this kind of welding though we didn't have a lot of issues with missing nuts.We are a contract manufacturer, we weld on several different weld nuts and fasteners per customer specs, however, we seem to have a re-occuring issue with missing weld nuts/fasteners. Some parts have several weld nuts/studs on them, some only one, obviously the parts with only one feature needing welding are never missed, however sometimes with multiple weld nuts/fasteners we struggle. Any additional advice would be appreciated.
Thank you.
Its forgotten weld nuts/fasteners.
Manual operation, and robotic is not feasible. Short runs of 100-1000 parts with 8- 30 weld nuts/fasteners per unit.
Thank you.
