I learned corrective actions a long time ago. Well before Ford started calling it an 8-D. Preventive action in those days was what you did (what we now call poke-yoke) to ensure that if your 'corrective' action failed the defect would be identified. To me, preventive action as it related to a corrective action is typically a poke yoke. Most of the 'hot words' are little more than variations on a theme, if you will.
Evolution of the definition of
preventive action has reached the point where the expectation is that you
predict failure modes - as I understand it. In automotive the
DFMEA and
PFMEA address the predictive aspect for the most part. In other sectors the ISO folks are asking that a company look at data and predict from that - as I understand it.
In so far as using the 8-D to 'track' the
potential problem, after some thought and reading I now agree. This is embarrassing as I have never been wrong before...
Some musings and some extracts from some listserves - with respect to ISO 9001:2000:
Element 8.5.3 of the new standard states that your organization must identify preventive action to eliminate the causes of potential nonconformities to prevent them from becoming real nonconformities. The preventive action taken must be appropriate to the impact of the potential problems.
The ‘old farts’ out there like me may have noticed an evolution of what a preventive action is. In days of old (well, the 1980’s) a preventive action was part of the result of a corrective action. It used to be what you did to ensure a problem which had already occurred would not again or would be caught through a Poke-Yoke or other mistake-proofing methodology.
Example:
Problem: Part not machined.
Reason: Tool broke
Root Cause: Feed Speed set too high – Operator error
Corrective Action: Revise tool change instruction, train operators.
Preventive Action: Sensor to check shaft OD post-operation to ensure cut was made. A failure will stop machine.
Things have changed to predictive (potential). The standard requires a documented procedure for preventive action that defines the requirements for:
a) identifying potential nonconformities and their causes;
b) determining and ensuring the implementation of preventive action needed;
c) recording results of action taken;
d) reviewing of preventive action taken.
Note that clauses 8.5.2 Corrective Action and 8.5.3 Preventive Action are almost identical, hence the processes that are developed for them will be very similar. It is strongly recommended that your organization use the processes developed for corrective actions to address preventive action to standardize the approach and make it easier to implement. The personnel with overall responsibility for preventive action are likely the same personnel with overall responsibility for corrective action.
Preventive action is action taken to eliminate the cause of a potential problem that has not occurred. Your organization has to ensure that the action taken is appropriate to the potential problem. The personnel who ensure it is appropriate preventive action should be the same people that ensure appropriate corrective action.
Preventive action focuses on studying your system and looking for where a problem might occur. Think data analysis, including looking for trends. Management then takes actions to ensure that the problem doesn't occur. Section 8.4.3 - Improvement processes - states that continuous improvement will be part of your management system. In other words, you look for both potential problems and opportunities for improvement at the same time. Thus, Preventive action and Continuous improvement can be easily combined.
To satisfy the requirements for preventive action you must develop a process for identifying the potential nonconformances and their causes, for determining and ensuring the implementation of the preventive action needed, then recording the results of the action taken and finally reviewing the preventive action taken. See corrective actions (8.5.2) herein for more background on this process and element.
The major difference between corrective and preventive action is that the nonconformances don't find you, you find the [potential] nonconformances. Some organizations find it quite a bit easier to be reactive and not proactive - preventive actions are not as common as corrective actions. The secret here is the ability to identify potential nonconformances and then correct them before they become actual nonconformances. This obviously is not easy, but invested interest in identifying nonconformances before they occur is well worth it - ask anyone who has had a product recall (I am sure we are all familiar with the recent news of product recalls).
Potential Audit Questions
1. How well integrated are your preventive action and continuous improvement actions?
2. Do you feel your organization seeks preventive actions enough? How could you do more to satisfy this requirement? How could your organization do more to excel at this requirement?
3. How does your organization identify the need for preventive actions? Do all workers identify preventive actions, or do you have a team or someone responsible for identifying preventive actions?
4. How does your organization assess whether or not the preventive action is appropriate? Do many preventive actions arise without ever being implemented? Why?
> From: ISO Standards Discussion
> Date: Fri, 29 Sep 2000 15:02:36 -0500
> Subject: Re: Q: Preventive Action /Conley/Andrews
> From: eandrews
--Patti inquired (in part);
--> We don't understand just how
--> far we need to go with preventive actions: do they need to be
--> documented & approved by someone, & then followed-up on
--> for effectiveness (similar to corrective actions)? Or is it
--> sufficient just to document what "preventive action" situations
--> have taken place & file them for later management review?"
> Patti,
> I have also encountered external auditors that come in looking for an entirely
> separate system for the handling of "preventive actions". What I have done to
> steer them in the right direction (toward proper interpretation of the
> 'intent' of the ISO 900X requirement) is to show the auditor where in our
> system preventive actions are incorporated. The topmost place in any QMS
> system to illustrate the presence of preventive actions is the existence of
> the system itself. The fact that you have a working QMS that requires
> management to periodically analyze the effectiveness of the system (internal
> audit results, customer complaints, internal nonconformities, etc.) with an
> eye toward undesirable trends is in and of itself a preventive measure
> (management is after all reviewing this information in order to improve the
> system where needed and thereby PREVENTING future problems). This is just one
> area of your existing system that you can use to demonstrate "preventative
> actions". I am sure that there are other areas within your existing system
> (supplier evaluations, training, etc.) that you can use as well.
> Hope this is helpful to get the 'ole grey matter' going.
> Ethan Andrews
