redknight07
Scope of the recast RoHS directive when compliance of components are considered seems quite complex to me. After reading several guidelines regarding this issue, I am confused as to how to interpret the following texts correctly.
One such article explaining the directive states that:
"Components, spare parts or unfinished products, as far as they do not fall under the definition of EEE are not considered EEE. Thus they don?t fall under the RoHS scope.."
So I would interpret that for components that are not an integral part of the equipment such as dummy weights with no electrical function used only for calibration and quality checks or straps made of nylon/some other material used to hold patient or software provided in a disk will not require compliance.
It then follows up with the following statements:
"Nonetheless components destined to be integrated/installed into equipment falling into RoHS scope have to comply with substance restrictions, independent of the fact whether they constitute an EEE or not.
Do components have to comply with RoHS 2?
RoHS 2 provides that EEE has to meet the requirements of the Directive. Since equipment consists of different components, the EEE itself can only meet the substance requirements if all its components and parts meet the substance restriction requirements of RoHS 2, including non-electronic or non-electric components like fasteners or the plastic case of a desktop computer. Therefore components being used in finished EEE or for repair or upgrade of used EEE, which is in the scope of RoHS 2 must meet the substance restrictions according to Art. 4 but do not need CE marking. Components sold as a stand-alone components or if produced to be used in a product benefiting from an exclusion do not have to be CE marked and do not have to comply with the substance requirements.?
I?m not sure if I am interpreting this correctly but I would believe that for components (non-EE) that are not contributing to the intended function of the equipment, they do not need to be in compliance. Am I correct in this assumption?
Would really appreciate your comments. Thanks. Apologies for starting a new thread if there are similar discussions ongoing.
Aniket
Aniket
