Is it normal for a procedure to begin with a conditional directive? (if statement)
biboy2012
My own answer is 'No', because task #1 should be the starting point of any activity, IMHO.
But......
Here is an example:
Activity Preface
These tasks are performed whenever a Customer Service Representative or anyone in the company recieves customer complaint.
If complaint received by Customer Service Representative?, goto task #1. Otherwise, goto task #22.
1. Receive customer complaint.
2. Log complaint in the system and indicate all the applicable information with corresponding Ticket Number.
3. Try to solve the issue on his/her own (1st contact resolution).
Any member of the organization
22. Receives complaint from customer and forwards the same to Customer Service Department.
End of activity.
Any thoughts would be appreciated. Thanks!
Re: Is it normal for a procedure to begin with a conditional directive? (if statemen
But......
Here is an example:
Activity Preface
End of activity.
If the nature of Task #1 depends on specified conditions, then the conditions should be specified before Task #1 is performed. What do you see as a better alternative?
biboy2012
No idea. The task #1 is dependent on specified condition. So, possibly the condition is the beginning point. Problem is how to identify the "performer" associated with the condition "If complaint received by Customer Service Representative?, goto task #1. Otherwise, goto task #22."
RoxaneB
Change Agent and Data Storyteller
As part of the procedure, you could indicate that all complaints are to be processed by a Customer Service Representative, so all employees have the responsibility to forward any received complains to the Customer Service Department (although, I'd make it one specific person, if possible). This takes away #22.
The "otherwise" defaults to anyone other than a customer service representative. Is that a problem?
qusys
Probably I did not understand well, but I would suggest to convey customer complainst into one unique and well identified channel of communication, not allowing lots of people directly deal with the customer ( customer representative or any other personnel).
:bigwave:
Q
Quality_Steve
I generally begin with what initiated the process. Such as:
[Customer complaint received.]
<If received by CSR then goto "B" otherwise goto "A">
[A - Complaint is forwarded to CSR]
[B - CSR logs complaint]
biboy2012
Received by whom? There are 2 performers identified by Job Title "Customer Serice Representative" and "anyone in the organization" and should be associated with task Customer complaint received.
RoxaneB
See my response above. ... or on page 1 of this thread.
biboy2012
Indicate where? For example, a procedure is composed of the following:
Scope
Policy
Responsibility
Distribution
Ownership
Task Segment
Activity Preface
Tasks
Which part of the procedure?
