Their requirement is in Procedure XYZ stating that ASQ Z1.4 will be used and AQL 1.0 is used on all products inspected.
I am not the customer they are making the products. I was one of four AS9100 auditors during a 5-day recertification audit.
There are three main requirements:
1)
AS9100D 8.5.1C2
Ensuring that when sampling is used as a means of product acceptance, the sampling plan is justified on
the basis of recognized statistical principles and appropriate for use (i.e., matching the sampling plan to
the criticality of the product and to the process capability).
There are two requirements in 8.5.1.C2
A) Sampling plan used has to be based on recognized statistical principle and appropriated for use.
Most commonly used plan meet this requirement. Whether it is appropriate depends on criticality of the product among other criteria.
It is a general requirement. It is up to the company to interpret and come up with their sampling procedures.
2) The
2nd requirement come from the company after they interpret the AS9100D standard and come up with their sampling procedures in the form of OP or WI. AS Auditor audit mostly to this requirement.
3) The
3rd requirement comes from interested parties. One example is from their customers. It may be in the Statement of Work or general Quality requirement or Quality clauses in the contract. I did ask about that, but could not get any answer. They have more than 8 key customers and it will take too much time to review the requirements. Customer may specify sampling plans to be used for their products.
I want to make it clear that the products from this company is critical. Failure could cause system or subsystems not getting signals to activate intended functions. If I have to issue a NCR, it would be vs their internal sampling plan procedure. Their Management established a sampling procedure that allows their Receiving Inspection staffs to accept lots with known defects found without screening the lots. It is a violation of 8.7.1. It would have been acceptable if this company manufacture cabin furniture, entertainment units... that are not critical. Again, their products are critical.
Some of the companies I audited use the same ASQ Z1.4 sampling plan, but add a note requiring the lot be rejected and screened 100%, if only one defect is found. Basically they are modifying this attribute plan to be a Zero acceptance plan. They could have just use ASQ H1331 and pick an appropriate AQL.
