Hami812
Engineering Program Mg
I have to perform a dry run on Minitab prior to a client a Gage R&R. I noted the client had previous performed what I thought was a Gage R&R< but as it turns out, it was an Attribute Analysis. Can the data used in Attribute Analysis be fitted for Gage R&R or does the testing have to be done differently? Also, when you consider Appraisers, can the appriaser be a PC? If you have 16 slots and your checking electronic blackboxes for some anomaly. Who is the real appraiser the guy who hits the button and awaits the pass/fail, or is the PC who collects the parametric data (unknown to the appraiser in a log file somewhere). Since the Auditor in this case will only want ot see the parametric data, can the operator be considered the appraiser or is it the PC with home grown software, and the parametric detection scheme (Data loggers, D/a COnverters, etc) are what is collecting data and deciding on Pass/Fail?. I have Minitab v16. This may be more a philosophy question, but i need to understand how to select the data rows and columns correctly for samples, appraisers, number of trials. Does the 16 slots testing these Blackboxes, count as number of times samples if they do the testing nearly simultaneously? Sorry.. I am getting hung up on details. I can provide sample data. Bit let me know.
