I am aiming to improve my risk management and I was wondering, if it could be helpful to combine the risk analysis with the 5M to list all causes systematically and not only the ones define.
Also I like to achieve a better assignment of hazards, damage and risk minimization measures, e.g. by having the hazards HZ-C1, HZ-C2 (Hazard-Chemical1-2) for the hazard category "Chemical Risks", to which the resulting damage H- C1 (Harm Chemical 1) and the required risk control measures are assigned RCM-C1-2. I like such a systematic structure, but I am not sure, if this is really an added value or just nice, that somone spend time to make the risk analysis bigger and look more "serious". Its nice for the CER and the risk management file, making it comfortable and easy to refer to the different hazards, harms and RMC. But is it worth?
In view of the fact that there are quite a few causes and that one could spontaneously overlook an aspect here, I had considered, whether the information on causes should also be further systematized here and I wonder, if the 5 M Method could be useful for this, i.e. specifying to what extent man, machine or milieu etc. represents the cause of a hazard or participate in it. One could work through these 5 points systematically and in the end you can make a better statement about the main causes for a dangerous situation from all these points, or you can identify the most and critical causes for it (if you weight the individual Ms against each other) and can then control them accordingly more or less intensively. Unfortunately, I have not found any information as to whether and what experiences there are with such a combination and therefore I would be delighted for a feedback, comments or also experience whit this
