Re: FDA Consultant Needed for Class I Device Development
I would appreciate any advice as to how I might locate a consultant who can help with regulatory issues, such as developing proper procedures and QA that will be needed by the FDA, and preparing a 510(k) for a simple Class I device.
A posting here, such as the one you just did, is likely to result in various consultants responding directly to you via PM.
I was wondering if there are other more selected forums to search in.
I don't think there's any forum that's superior to here. Of course, in the end, wherever you find the help you need will be the location that you'll think is superior.
You might be able to obtain the regulatory help you want from the same outfit that does your contract manufacturing. There can be advantages in such an approach, since communications and controls regarding materials choices, biocompatibility issues, etc. are not a problem.
On the other hand, you as the regulatorily responsible Manufacturer of the product are obligated to Register, List, and have a 21CFR820-compliant QMS. It's unlikely that a contract manufacturer would be equipped to provide such assistance; a consultant would be a better fit for that work. Or, you might begin to add employees to do that work, as well as prepare for marketing and other business operations.
Are you also considering alternate, easier/cheaper-to-start-up business approaches such as licensing your device to an interested device maker in return for sales royalties or some other arrangement?
I have designed and will be contract-manufacturing a device for which I would like to receive Class I exempt status. (I say Class I exempt based on the existence of predicate devices which were also determined to be exempt after submission of their 510(k).)
Just as a clarification, all Class I devices other than a very few that have special status are Exempt from the 510(k) pre-authorization process. Usually a "Class x Exempt" statement is in regard to a Class II device that fits into a Product Code that has such Exempt status...an example being KXJ, for radiolucent patient support devices such as an imaging table.
Generally speaking, if your identified Predicate Device has a 510(k), your device will as well. If on the other hand your Predicate Device is classified as Class II Exempt, it won't have a 510(k) specifically because it's Exempt from that requirement.
