How to Contractually Agree on Specifications for Raw Material Purchases
zac2944
Looking for ideas on how to manage supplier specifications for my raw material purchases. More specifically, how to you contractually agree on what specification is to be produced in a given order?
My company has a policy that requires my engineers to obtain a signed copy of our raw material specification. The spec details all the requirements for the item, we sign it and the supplier signs it, and then we refer to that specification on our purchase order. Problem is that obtaining signed specifications is very resource intensive and internal audits are showing that it is often not done.
There is typically an agreement via email or over the phone between my engineers and the supplier's engineers. We get some sample material, test it, and then rush into production without finalizing the specification and getting signatures. The risk here is that if we have a huge customer complaint that is a result of a raw material issue we have no record or contract that supplier agreed to manufacture to our specification. Most suppliers would own up to this, but when you're into 7 figure issues that might not be the case.
I proposed a different method but I'm not sure if it will work. I'd like to program our purchasing computer system to include a copy of the latest raw material specification when we send out a purchase order, and then in the PO boilerplate state that by acknowledging and accepting the order the supplier agrees to manufacture to the included specification. This would make it a contractual agreement and relieves us of the paper chase trying to obtain signatures.
Sound like a crazy idea? How do you all accomplish this? What is the best practice here?
Thanks in advance Covers. This is my first post since Elsmar rose from the ashes. Feels like talking to a ghost. :D
Michael_M
Re: Supplier specification agreement
If I read your post correctly,
In our ERP software, we have each raw stock item named, for example: "SSRD155PH-00375". In the description of the specified material, we have: "3/8 Rd. 15-5 PH Stainless Steel per IAW AMS 5659"
On the Purchase order, we state 'to latest revision, unless specific instructions otherwise'
When a PO is created, we pull up the SSRD155PH-00375 and it auto fills the description including the AMS 5659.
Another example: "ALRD7075T7351-01375", which is "1 3/8 RD. 7075-T7351 ALUMINUM PER QQ-A-225/9"
normzone
There is typically an agreement via email or over the phone between my engineers and the supplier's engineers. We get some sample material, test it, and then rush into production without finalizing the specification and getting signatures. The risk here is that if we have a huge customer complaint that is a result of a raw material issue we have no record or contract that supplier agreed to manufacture to our specification. :D
If you have email you have a record, and that is a contract at the most basic level. I could live with emails as specifications if they contain enough information (P.O. number and material spec reference) and come from an appropriate person in the supplier's organization.
Phone conversations are as good as the paper they are printed on. I've seen people get burned by making major changes based on phone conversations, and then the source of the changes leaves the organization and there's nobody to turn to.
Coury Ferguson
Moderator here to help
This sounds like a reasonable attempt and control. However, are you talking about sending a copy of the Material Specification with every order, or just having it referenced in the body of the PO (Legal Binding Document)? Most Raw Material Suppliers have a copy of the required material specifications.
BoardGuy
This is a no, no under AS9100 as you must spec the identification and revision of specifications you are ordering to.
Under contact law you may have a problem here because the terms and condition of seller take precedence over the customer PO term and conditions. So if the latest revision on hand at the supplier is three revisions lower than what is wanted you may not have a leg to stand on to reject the product because who’s latest revision was not specified in the contact.
[FONT=&quot]Another option I have seen which uses the term “latest released revision of specification XYZ” may be appropriate but there still could be ambiguity of requirements even with this term being used.[/FONT]
howste
Thaumaturge
I don't see that AS9100 is a requirement for the OP. Also, AS9100 Rev C states "revision status of specification" not revision of specification. Rev D has no mention of the revision.
I'm no lawyer, but I don't believe this is always true. The contract terms that take precedence are the ones that are agreed to by both parties. If there is no formal agreement made, my understanding is that the "Last Shot" rule applies and whoever sent their terms last wins. If the buyer sends terms with payment, and the seller ships the product with no further terms, then the buyer's terms rule. If I'm wrong, I'd would like an explanation.
BoardGuy
7.4.2 Purchasing Information
Purchasing information shall describe the product to be purchased, including, where appropriate:
d) the identification and revision status of specifications, drawings, process requirements inspection/verification instructions and other relevant technical data.
Also we have talked about this on the cove here: https://elsmar.com/Forums/showthread.php?t=48735
BoardGuy
[FONT=&quot]Depends of which state the adjudication will occur. Just pointing out this could be an issue when you do not specify.[/FONT]
Coury Ferguson
I have seen POs from OEMs and a like, that require a earlier revision to specifications. Some Customers, want the earlier revision. So, the best way to handle that would be to specify in the Body of the PO what specification is warranted/required. Whatever is required, needs to be in the Body of the PO and/or drawing.
Just my opinion
zac2944
I would actually include a copy of my specification with the PO. My system uses the body of the email as the po. There is a line item with an ID number for the item and a description. We currently do not reference the item number (specification) revision on the PO line.
My engineers are required to have the supplier sign a copy of the latest specification, but it doesn't always get done which leaves us at risk.
My hope was that by sending over a PDF of our specs as an attachment to the email PO, and referencing the Spec and Rev Level in the PO line description we could do away with the signed copy. I would add a line to the PO boilerplate saying that acceptance and acknowledgement of this PO means you agree to supply per the attached specification. Of course that would have to be translated into lawyer-speak.
I'm not an AS9100 company. We're 9001 and supply flexible packaging material (pouch stock, lidding, ext.) to the food/pharma industry.
R Do you agree with "There are no stupid questions" statement? Coffee Break and Water Cooler Discussions 40
P Safety Signs - Do you agree that safety signs should be uncluttered? Manufacturing and Related Processes 6
B Must I agree to an IATF Witness Audit? Registrars and Notified Bodies 16
P Do You Agree: Older People Are More Innovative Coffee Break and Water Cooler Discussions 2
H How do I answer an audit finding I don?t agree with? Nonconformance and Corrective Action 17
Jim Wynne Ford, UAW agree to offer buyouts to ALL hourly employees World News 0
K ASME, ANSI, ASTM and similar specifications and their requirements for document control. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
R EU-MDR Article 9-common specifications Other ISO and International Standards and European Regulations 2
A Oven Controller Specifications - BAC5621 and AMS2750F AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R BS EN 12060:1998 - Zinc and zinc alloys Method of sampling Specifications Manufacturing and Related Processes 4
M MDR "Common Specifications" (CS) - If not standards, then what? EU Medical Device Regulations 5
G Engineering Specifications - APQP APQP and PPAP 5
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
DuncanGibbons OEM specifications such as AIPS spec from Airbus AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
E Packaging Specifications Mercedes-Benz U.S. International IATF 16949 - Automotive Quality Systems Standard 4
C Taking exception to customer requirements or specifications & AS9100D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
P Software requirement and design specifications - Medical device contains both hardware and software IEC 62304 - Medical Device Software Life Cycle Processes 2
M Informational EU – Draft Functional specifications for the European Database on Medical Devices (Eudamed) – First release (High(1)) to be audited Medical Device and FDA Regulations and Standards News 0
M Specifications Aerospace - Who is responsible for providing the correct specification(s) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
D Raw Material chemical/Tensile Requirements Specifications (QQ-A-250/4, etc) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
2 ASTM or ISO Specifications on Prints Other US Medical Device Regulations 2
R Control of COTS (Commercial Off The Shelf) Specifications ISO 13485:2016 - Medical Device Quality Management Systems 2
I Procedures from recognized standards or specifications ISO 17025 related Discussions 3
S Test Specifications based on Vehicle Type Various Other Specifications, Standards, and related Requirements 0
P Help with 8.5.1 regarding Welding Procedure Specifications (WPS's) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A Technical Documentation - Manufacturing Specifications EU Medical Device Regulations 4
J Change in Lot Release Specifications - Definition of "Substantial Change" EU Medical Device Regulations 14
T ISO 13485 Label Specifications and Artwork Control ISO 13485:2016 - Medical Device Quality Management Systems 3
alonFAI SMT machine specifications and performance meet the requirements for our production Manufacturing and Related Processes 2
N Subscription Service to Raw Material Specifications AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
W Japanese Steel Specifications - A material called HNCM220M Manufacturing and Related Processes 1
A Procedure for Labeling Review and Approval and Specifications Matrix US Food and Drug Administration (FDA) 2
M Design Inputs - Final Medical Device Specifications 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
Q How to handle customer request for changing specifications 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
O Functional Specifications - Tracability to requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
H Resistance Temperature Detectors (RTD) Manufacturer's Specifications General Measurement Device and Calibration Topics 3
K Thermocouples Hot Junction and Number of Uses Specifications AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K What is included in Raw Material and Component Specifications for Medical Devices? Other Medical Device Related Standards 3
A Are Software Requirements Specifications part of Design Input? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
T How to keep Customer Engineering Specifications & CSRs Up to Date IATF 16949 - Automotive Quality Systems Standard 6
N Control of Documents Scope - Product Specifications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
O Specifications as requirements? Other US Medical Device Regulations 8
W Who in your company writes your policies, procedures, specifications etc. Document Control Systems, Procedures, Forms and Templates 10
M Thread Ring Gauge Specifications General Measurement Device and Calibration Topics 3
U Looking for Bolt Thread Specifications for Delrin & Aluminum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Standards or Specifications required for Garbage Truck Compressors Various Other Specifications, Standards, and related Requirements 1
V Where to get MS501 Chrysler Specifications APQP and PPAP 3
V Evaluation of Paint Specifications including such as GM 9984123 and GM 14671 APQP and PPAP 1
D M6X1 Thread Specifications Manufacturing and Related Processes 7
