How to decide a suitable contact time from table 23 of IEC 60601-1:2005
Roland chung
Hello all,
It is a power adaptor under test. The plastic enclosure of the adaptor is 81[FONT=&#23435]℃ at maximum ambient of 40[FONT=&#23435]℃[/FONT]. Table 23 specifies the maximum limit of 86[FONT=&#23435]℃[/FONT] for t <1s and 71[FONT=&#23435]℃[/FONT] for 1s£ t<10s. [/FONT]
The standard also says the probability of occurrence of contact and of the duration of contact is determined by the RMF. We then documented t < 1s rather than 1s < t< 10s in the RMF just because of we think the power adaptor is not a handle or control panel which in normal use would have a brief or long contact with a user. So, the measured temperature 81[FONT=&#23435]℃ is below the limit 86[FONT=&#23435]℃[/FONT]. Is it reasonable? [/FONT]
In addition, could someone give some examples (equipment parts) for each contact time specified in the table 23 of IEC 60601-1:2005?
Thanks and regards,
Roland
The standard states that the figures in Table 23 are valid for a healthy adult. What is the likelihood of more vulnerable users touching the power supply?
And if the touch was as a result of attempting to pull the power supply from the socket (is it a plug top type?) then t<1 second would not be reasonable estimate.
Roland chung
I can not get your point. Please be reminded that even limits in Table 24 (applied parts) are derived from healthy adults.
No, it is desktop adaptor.
Peter Selvey
I think the figure of 81C is high if it appears in normal use, and advisable to reduce even just from a sales point of view. I would be a worried and potentially complaining user if things are that hot. It's hot enough to damage things that are sitting near it, for example.
But, it's also likely the measurement is made with a bunch of worst case assumptions. For example, 40C ambient + max load + worst case supply voltage, longest use time etc etc.
Statistically, the probability of all parameters being worst case at the same time is usually negligible. That might be a factor in the risk analysis and also the sales issue.
Apologies if I was not clear.
What I was suggesting was that if the person who may touch the hot power supply was, say, a child or a patient with reduced feeling (perhaps a stroke patient) then the 86 C limit would be too high.
However, if the person who is likely to touch the power supply is a healthy operator then it should be valid. And this also applies to the time part. A healthy operator may brush over the power supply without any harm occurring.
Roland chung
Thank you all!
Yes, the test indeed conducted under the conditions as you mentioned and is also a normal heating test.
We actually don't know who will touch the power supply. It is up to the intended use of the end products.
The power of general adaptor is about 65W, but our adaptor is 150W, so the temperature is a little bit high.
Roland chung
I would like to ask a question in regard to the temperature limit of enclosure in SINGLE FAULT CONDITION.
According to the clause 13.1.2 of 60601-1:2005, the temperatures of ME EQUIPMENT parts that are not APPLIED PARTS but are likely to be touched shall not exceed the allowable values in Table 23. That means the limits of Table 23 shall apply in both NORMAL CONDITION and SINGLE FAULT CONDITION.
In my case, it is a power supply. The measured temperature of plastic enclosure under overload condition is 90 C, which exceeds the 86 C limit (Table 23, contact time < 1s). Is it clearly a failure? Is there an alternative method to pass the standard?
Roland
silentmonkey How to decide what characteristics need to be verified during incoming inspection? ISO 13485:2016 - Medical Device Quality Management Systems 5
S How to decide which medical device symbols go on label and labeling? US Food and Drug Administration (FDA) 5
J ISO 9001 - How to decide if a company needs or will benefit from certification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
L Help me to decide which test to use - If each proportion belongs to the same population Using Minitab Software 7
T Can we remove a quality objective if we decide it is not measurable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B How to decide on a sampling size for Xbar-R charts Statistical Analysis Tools, Techniques and SPC 2
J How to decide work-stream in scope of Quality - Roles and Responsibilities ISO 13485:2016 - Medical Device Quality Management Systems 1
D Service Identification - How can we decide if X is a service or not? Lean in Manufacturing and Service Industries 4
C Medical Device Manufacturing in Controlled Environment? How to decide? Other Medical Device Regulations World-Wide 1
M Statistical Method to decide Threshold Value from a Data Set Statistical Analysis Tools, Techniques and SPC 1
P Gauge Design Tolerances - How to decide tolerances for gauge design? General Measurement Device and Calibration Topics 3
C Starting an MSA study - How to decide which is appropriate or required Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Lean or Six Sigma or TOC (Theory of Constraints) - How to decide Lean in Manufacturing and Service Industries 6
H How to decide AQL value? Sampling Plans AQL - Acceptable Quality Level 5
A Who to decide and select Internal Auditors and what are the criteria? Internal Auditing 18
M CAPA Rankings to decide if action is required Nonconformance and Corrective Action 7
D Who should decide on my salary and adjustments? Career and Occupation Discussions 9
P How do you decide what is an acceptable Internal and External PPM number? IATF 16949 - Automotive Quality Systems Standard 17
M Overhaul QMS or start over? How do you decide? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 40
P How do you decide what is a Process, a Procedure or Work Instruction? Document Control Systems, Procedures, Forms and Templates 89
J To Decide Which Factor has the Highest Influence on the Results Using Minitab Software 3
K Regulatory Requirements for ISO 13485 - Which country to decide? ISO 13485:2016 - Medical Device Quality Management Systems 6
B How to decide the ?U? to calcuate DPU and "opportunity" of DPMO Six Sigma 8
L Is the EPA is going to decide if the SPCC deadline is to be extended? Miscellaneous Environmental Standards and EMS Related Discussions 1
M CA (corrective action) or Continuous Improvement? It's hard to decide. Nonconformance and Corrective Action 19
M how to decide the submission level for PPAP APQP and PPAP 2
Y How do we use SPC or other stat tools to decide product spec? Statistical Analysis Tools, Techniques and SPC 5
D On-going capability - Can we decide for ourselves how often to measure cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 6
A The requirement of the PMS plan--suitable indicators and threshold values EU Medical Device Regulations 0
S Two or more predicates suitable? 510K submission US Food and Drug Administration (FDA) 5
M Informational FDA Classifies Suitable Accessories into Class I as Required by the FDA Reauthorization Act of 2017 Medical Device and FDA Regulations and Standards News 0
M Suitable form or questionnaire for approving consultants Document Control Systems, Procedures, Forms and Templates 9
Q Recommendation for a suitable PA on a complaint received Preventive Action and Continuous Improvement 3
D Suitable CE Mark Directives - Product Families CE Marking (Conformité Européene) / CB Scheme 3
S Suitable Protocol for Isolation of Clostridium perfringens Food Safety - ISO 22000, HACCP (21 CFR 120) 2
S PCR suitable for detection of Salmonella Food Safety - ISO 22000, HACCP (21 CFR 120) 1
K Intended Use wording: What is suitable for the instruction manual? EU Medical Device Regulations 4
S Protocol of water activity measurement and suitable instrument Food Safety - ISO 22000, HACCP (21 CFR 120) 1
S Choosing a suitable type of Elisa to Test my Sample Misc. Quality Assurance and Business Systems Related Topics 3
R Is IEC 60601-2-37 suitable for Fetal Doppler Detector? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
K What kind of people are suitable for Quality Management? Career and Occupation Discussions 12
R Is INMETRO certification suitable for medical device components? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
D Electronic Document Control System suitable for TS 16949 Requirements Document Control Systems, Procedures, Forms and Templates 2
M IVD Annex III Path - Suitable Quality System (e.g. ISO 9001, ISO 13485)? EU Medical Device Regulations 2
V What are suitable "Leading Indicators and Metrics" for QA Quality Tools, Improvement and Analysis 7
B What is "Use of suitable production equipment" - ISO 9001 Clause 7.5.1 c) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
W Calculation of % defectives to determine suitable AQL Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
O Chemical composition of plastic compound suitable for manufacturing plastic gears Manufacturing and Related Processes 9
H Can you tell me a suitable "tooling" for Caliper Calibration - ISO 17025 ISO 17025 related Discussions 16
J Measurement Uncertainty (MU) - Genetic Testing Lab - Lack of suitable CRM - ISO 17025 ISO 17025 related Discussions 6
