Ethicon does not mfg bladeless Xcel trocars in 10mm and wanted to know if this product would still do the job similarly as i need 10mm ports: (511NT 10/11mm Ethicon Endopath 10/11mm Bladeless Trocar with Stability Sleeve, 100mm)
Would the above trocar work properly when using 5DSG (Ethicon Endopath 5mm Grasper with Ratchet Handle ) ? The grasper cannula must be 5mm or smaller so it can fit itself + mesh comfortably in the trocar
