we are a company at MDR/ISO 13485 landscape and as such, we monitor our measuring equipment as we have to.
In the past this was done periodically, depending on risk-based requirements, by accredited calibration labs or for lower-tier stuff in-house with documented and recorded processes, against standards or against reference meters. Intervals are derived from useage, stability between periodic calibrations and generally how well stuff behaves (and somewhat price) also according to a documented process.
To gain confidence in a bunch of meters and loggers I started to introduce online monitoring campaigns, mostly guided by "there is a computer readout for it" and hierarchy. This includes e.g.
The main reason to do this to have a early warning system, triggering process evaluation and inspection of tools/gauges.
How do I link the results of those inline/online/continuous (of course you can consider it that after trials this are all very well documented and validated processes) data to the periodic calibration?
Are there guidance or standards about
I'm clear that it is our requirements and needs to be risk-based, but is there anything I should read before thing about those things?
BR
Hendi
- a display and logging program for room climate loggers spread in the building that periodically records deviation of air pressure between loggers,
- another program logging atmospheric pressure reading from one of the low-tier bunch above against a highest-tier pressure gauge (recognizing the effect of height-dependent barometric pressure)
- The same highest-tier pressure scale is periodically compared against a medium-tier device at low, high and midpoint.
- Other example are placing transport loggers on top of the room logger and record temperature deviation after a equalisation time, or
- sticking a higher-tier Pt100 Thermometer in a heating cabinet,
- and so on.
- deriving e.g.calibration interval from monitoring?
- Is "inheritance" possible if specified?
- Replacing a inspection+measurement session by "just evaluate last values from the log and call it a day if it fits requirement X" ?
BR
Hendi
