K
After joining a new employer in August of this year, we had a Nadcap audit for the internal testing lab last week. One of the identified nonconformances is confusing me, we sought additional informatin during the audit and didn't succeed in getting anything more than "that is the requirement". We machine round tensile specimens from various size bars and billets to ASTM E8 dimensions. Blank specimens are cut from raw samples using water soluble oil cooled bandsaws. Tensile specimens are turned on CNC lathes, again with water soluble oil cooling, and as one continuous process, from blank to final size. We 100% check the final dimensions on all turned specimens.
The checklist cited was AC7107/7 C, paragraph 6.1.b Paragraph 6.1 states " Blanking is performed by methods which do not distort the material or produce surface sffects deeper than would be removed by final finishing." Subsection b states " A minimum of 0.010" (0.25mm) remains on rough machined surfaces for final finishing operations."
The expectation of the auditor was that we should stop the CNC lathe operation 0.010" shy of final dimensions, check the that a minimum of 0.010" remains, record that dimension, and then resume machining.
My opinion is that blanking is what we do when we cut the rough sample specimen from the mill sample, or when we rough machine a tensile specimen prior to heat treating it (we leave more than 0.010" to machine in this case), not stopping midway through machining to verify that we still have 0.010" left. Our final cut for the reduced section of tensile specimens is significantly less than 0.010" so that we can generate an adequate surface finish.
I'm a little bit lost here as most prior experience was either automotive related (ISO/TS) or ISO 17025 related for testing labs. Does anyone have any experience with an interpreted requirement such as the one cited, or any suggestions in dealing with it? Thanks for any words of wisdom.
