Not using gloves in Clean Room Class 8 (ISO 14644)
Ninja
Looking for Reality
#11
Re: Not using gloves in Clean Room Class 8 (14644)
Your Nadia reference kinda gives your age away :lol:
Yup...I'm starting to feel older, so it must have happened a while ago:D
Thank you for adding in the "medical side". I don't work in that area so I do not know the additional requirements that may exist.
Ninja
Looking for Reality
#13
Imagine if all of the men in the classified room begin contributing to the PM count unknowingly...
Clean room gowning and behavior is perhaps one of the greatest challenge to the clean room class in normal condition of use.
This is the perception I come across most frequently. ...and that's why I keep the mantra going. It is about the air.
Somehow there is a mystique about the bright white shiny walls, only seeing someone's eyes and a field of white tyvek, the looking into another world that looks like a hospital surgery...that makes it seem like the word cleanroom is holy, or sacred. And we look at spending money to maintain the mystique.
.....but it is about the air. ....
it is WAY cheaper to increase the airflow in the room than to maintain the supply of coats/bouffant hair covers/booties/tack mats/daily scrubs and washdowns/line closures for wall scrubs/behavioral mod training/and on and on.
For class 10k and class 100k...just add air. The cleanroom class is determined by the level of AIRBORNE particles. ..if you just overpressure the room enough (pretty much a one time capital expense which is easier for the bean counters to swallow)...all those dirty hands, hair and clothes generate particulates that do not stay airborne in the room and thus dont matter.
When I say, its about the air.....dont stop at measuring the air....its all about every aspect of the air. Flow, volume, laminar speed, humidity inlet particle count (HEPA aint perfect ).
Dont fall for the bright white glamor and pretty eyes dressed in white. Pay attention to the air...the inlet, the directions of flow, the escape paths, the degree of overpressure. ....and when you go to look at gowning for a class 10k room.......go back and look at the air again. It truly is all about the air. Upgrading your blower to a higher capacity is cheaper and more effective than one months supply of tyvek coats and latex gloves.
keep in mind that my living room has four upholstered pieces of furniture, five plants with associated dirt and pollen, a large rug, curtains, and two people using it every day...and it measures at 34k simply because of the centrl air ducts. Imagine how simple 100k for the OP really is....
SMBIZZQA
#14
My question really isn't regarding gloves, but as a sidenote we operate a "controlled environment" and have frequently been requested to wear gloves for products by customers.
My question is, has the particulate levels changed in the ISO14644-1, 2016 revision or are they the same, i.e class 9, 35,200,00 for.5
Ajit Basrur
#15
First of all, welcome to the Cove :bigwave:
A small correction - the new ISO 14655-1 is 2015 and not 2016.
For ISO Class 9, the maximum allowable concentrations (particles/m3) for particles equal to and greater than the considered sizes are as follows:
0.5 micron: 35 200 000
1 micron: 320 000
5 micron: 293 000
L
Laughing Pierre
#16
Just for info.
The Institute of Environmental Sciences and Technology in their publication IEST-RP-CC003.4, Garment system considerations for cleanroom and other controlled environments, has a table for recommended garment system configurations applicable to various cleanliness environments. The recommendation for barrier gloves is that they are recommended for use in Class 1 to Class 5 (for aseptic) and their use in Class 5 to Class 8 is application specific. I offer this as information only as it comes from a well respect document from a well respected institute and in a way 'validates' many of the posts in this thread.
patilrahuld
#17
Can someone share the SOP for cleanroom certification? We are certifying to class 8 cleanroom and wanted to understand the procedural approach.
GStough
#18
Have you checked the Post Attachment List in the link above (under The Elsmar Cove Discussion Forums link, beside the Solutions lighthouse)? There are some files posted there which you might find useful.
I hope this helps. :bigwave:
thnksnow247
#20
What is driving the need to control particulate on the product? Is is a bio burden control, process quality, or packaged device cosmetics issues?
I have seen a lot of med device manufactures get away with no gloves in a clean room. The reality is very few manufactures do direct particulate testing of there product beyond visual inspection often through a package. Only when you start doing particulate testing on your device do you learn that room air quality is only one small part of producing a clean device. Part handling, work flow, device cleaning methods, and cleanliness of equipment have a huge impact. A lot of particulate generated never really gets airborne, but exist on work surfaces.
Bio burden is relatively well controlled with a good hand washing procedure. Gloves and face masks are definitely better though.
There are many processes that benefit from running in a cleanroom even if they are simple like LCD screen overlay assembly. Gloves might not be important in such an application and the additional handling problems from gloves might be a bigger problem than particulate from hands in terms of yields.
There also may be a need to limit particulate from a customer quality perception standpoint. Gloves may not be critical for such an application.
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
J Using ring gauges General Measurement Device and Calibration Topics 2
P Can Neoprene be Cleaned Using Isopropyl Alcohol (IPA) Manufacturing and Related Processes 4
GreatNate Anyone using the Intellect QMS software? Quality Assurance and Compliance Software Tools and Solutions 1
chris1price Sterilization using beta radiation Other Medical Device Related Standards 2
M Using the phrase "herein referred to" Document Control Systems, Procedures, Forms and Templates 8
B Struggling with using the 5.6 version Ford Capacity Analysis Report APQP and PPAP 5
rerusk1 MRB (Material Review Board) Process using MS Sharepoint or MS Teams Manufacturing and Related Processes 2
U Medical Device CE Marking - Using a disposable bearing CE Marking (Conformité Européene) / CB Scheme 3
W Using tailoring guidelines to tailor a QMS procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Y We found out we have been using a equipment without validation for past 4 years Quality Manager and Management Related Issues 6
D Using Laboratory Notebooks in R&D and Design and Development ISO 13485:2016 - Medical Device Quality Management Systems 3
C Importer shell game - Using a third party logistics provider (3PL) in the EU EU Medical Device Regulations 5
S Work performed in Canada on US patients using US device Canada Medical Device Regulations 1
Tagin Evaluating nonconformances for escalation using Bayesian methods? Statistical Analysis Tools, Techniques and SPC 2
D Using non-conforming components even though the final assembly is conforming? Manufacturing and Related Processes 5
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
R Clause 7.7 Replicate, Recalibration and Intermediate checks using Artifact ISO 17025 related Discussions 1
Stoic Are any medical device companies using the 2011 FDA process validation guidance instead of GHTF/SG3/N99-10:2004? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B Unit of Use DI (Device Identifier) - Products using the same device US Food and Drug Administration (FDA) 0
A Using Arduino based sensors for Poke-Yoke Manufacturing and Related Processes 6
M Using your Manufacturer's ISO certification ISO 13485:2016 - Medical Device Quality Management Systems 5
Ed Panek Adverse Event Clinical Trial using a 510K approved Device Other US Medical Device Regulations 6
B Using non CE parts in a machine CE Marking (Conformité Européene) / CB Scheme 1
A Hospital IT expectations for connected medical device using WIFI Medical Information Technology, Medical Software and Health Informatics 0
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
B Using external FDA and ISO 13485 audit as internal audit Internal Auditing 6
J Class 1 Medical Device - Using a UPC over the UDI? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
I Reducing CE marking cost using manufacturer test reports CE Marking (Conformité Européene) / CB Scheme 5
CPhelan Using clinical trial safety data for evidence for CE marking EU Medical Device Regulations 8
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate Qualification and Validation (including 21 CFR Part 11) 3
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate General Measurement Device and Calibration Topics 2
M Raw stock material testing discrepancy using an XRF (x-ray fluorescence) analyzer Manufacturing and Related Processes 7
Z Using FMEA for Knowledge Management FMEA and Control Plans 6
Sidney Vianna NASA to Develop a Novel Approach for All-Electric Aircraft Using Cryogenic Liquid Hydrogen as Energy Storage World News 2
S How many of you are using Robotic process automation for calibration lab management? ISO 17025 related Discussions 0
J Including Repeats in DoE using Minitab Using Minitab Software 5
S Legal Manufacturer FDA Reporting Obligations for Using New Contract Sterilization Site Other Medical Device Regulations World-Wide 0
John Predmore What size pinhole can be reliably detected using visual inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
D I'm new in IMDS special using the IMDS application Manufacturing and Related Processes 8
