Powder Weight Proportion Measurement Gage R&R
sinned
Registered Visitor
Help!
We have a measurement on powder particle size proportion using a set of sieves and an electronic scale. During measurement, the powder is sieve to obtain particles of certain sizes and use a scale to weight how much powder is left in the different sieves.
Question: to perform a GRR study of the measurement system, should i include the sieving into the system? Or just the electronic scale measuring the weight of powder ?
If it's the former case, I need to get the 10 samples through sieving and weighing. Should i?
We have a similar process in my organization. The sieves are a critical element of measuring the particle size distribution so you must have replicate measures of the whole system not just the scale. This is a functional measurement system - so how you set up the test is critical. Technically it is a nested study as the powder cannot be measured twice (lots of powder in the sieves during the first measurement will seriously effect the study results. And different particle sizes will be effected differently due to their mass and the effect of static and vanderwall's forces...
The approach that I found to work best is to take a large sample of powder that will most likely be homogenously mixed and break it into enough sub samples for each replicate you will be testing (If doing the common 10 X 3 X3 study you will need 6 sub samples of 10 different lots).
Make sure you clean the sieves fully in between each rep...
sinned
Registered Visitor
If this is true, what about the measurement on ash content of powder ?
This involves measuring the weight of material before and after burning in oven with a scale. Do i also need to include the burning process into the system?
sinned
Registered Visitor
Thanks for your advice.
I will try to arrange for that and see how well we can get about the GRR. I am not optimistic on the result as it will be difficult to get samples of full tol. range. To your experience, how well will the GRR be ?
Why do you think you need batches with the full range of the tolerance?
The outcome of the GRR will depend on many things, primarily your specifications I'm guessing. In our case the specifications were fairly narrow - and unfortunately they needed to be. so our GRR wasn't great at all. We compensated by always taking 3 PSD readings. WE also discovered that PSD is not homogenous within a lot and so we took PSD measurements for each sub-batch of material that we were going to make product with. while our GRR wasn't great we could see the differences between batches and this allowed us to greatly reduce our scrap due to poor PSD.
O Freeze-Dried Powder Sterility Test using the Membrane Filtration Technique Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
P Powder Coat Painting Jigs (Hangers) for Shafts and Joints Manufacturing and Related Processes 3
Q Weighing Dietary Supplement Powder during manufacturing US Food and Drug Administration (FDA) 2
L CQI-12 2nd Edition - Table D, question 2.1 - Powder Coat Painting IATF 16949 - Automotive Quality Systems Standard 2
S Glove Protein Content in μg/dm2 to μg/g and Powder Amount mg/dm2 to mg/glove Other Medical Device Regulations World-Wide 4
S Where to get GM 4348M Paint or Powder Coating Standard Reliability Analysis - Predictions, Testing and Standards 1
C Approval and Release of a new Powder Coating - Which tests should be done? Manufacturing and Related Processes 2
M Looking for a Powder Coating Process Instruction Manufacturing and Related Processes 3
K Process Audit Checklist For Powder Coating Required Process Audits and Layered Process Audits 2
N FDA vs ASTM - Limitations of Powder Content in Gloves Other Medical Device Regulations World-Wide 3
T Control Chart - Salt Spray Test Hours - Powder Coated Parts Statistical Analysis Tools, Techniques and SPC 3
A Does any friend have the Powder Coating Control for Aluminum Parts? Supplier Quality Assurance and other Supplier Issues 3
M ISO 22000 - HACCP plan for ingredients like Egg Powder, Strawberry Flavour and Butter Food Safety - ISO 22000, HACCP (21 CFR 120) 2
A Powder Coating Chipping for Aluminum Die Casting Parts Supplier Quality Assurance and other Supplier Issues 11
B Fabricated Dry Powder Storage Tank - Initial Cleaning Food Safety - ISO 22000, HACCP (21 CFR 120) 5
V Creating a Cosmetic Inspection Specification for Powder Coated Painted Finished Parts Manufacturing and Related Processes 7
W Powder Coating Adherence to sharp edge of Steel Manufacturing and Related Processes 6
M What is the difference between "Powder coating" & "Polyster powder electropainting"? Manufacturing and Related Processes 7
T Age Sensitive Materials - Identification and Traceability procedure - Powder Coat ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
S Need Polyester type Powder Coating information Manufacturing and Related Processes 4
J Powder Paint Supplier Audit Questions Checklist General Auditing Discussions 3
Q HACCP Milk powder/dried milk manufacturer auditing Food Safety - ISO 22000, HACCP (21 CFR 120) 1
S Process Capability Study for Electrostatic Powder Coating Statistical Analysis Tools, Techniques and SPC 6
M Brass, Bronze & Copper. Will their chips or powder be harmful to CNC Machines? Manufacturing and Related Processes 4
C Cost per Piece of Powder Painted Part Manufacturing and Related Processes 3
P Light Measurement Help - Work Instruction for Inspection of Powder Coated Surfaces Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
T DOE (Design of Experiments) for Powder Coating Thickness Six Sigma 9
T International Standard(s) for Instant Drink Powder Various Other Specifications, Standards, and related Requirements 4
L Powder used to make neodymium magnets - GR&R for destructive testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Seeking: Powder Coating on Steel Test Method or Procedure Various Other Specifications, Standards, and related Requirements 10
M Alloy Wheels - Seeking Paint Supplier - Powder Primer, Liquid Base, etc. Misc. Quality Assurance and Business Systems Related Topics 1
W Metal Finishing - Powder Coating and Painting QS-9000 - American Automotive Manufacturers Standard 6
D Life of the part - How long should I keep processing data, powder, raw material tests Document Control Systems, Procedures, Forms and Templates 3
S CQI-23 - Molding System Assessment - Control of part weight IATF 16949 - Automotive Quality Systems Standard 5
M Informational FDA discussion paper – Consideration of Benefit-Risk Approaches for Weight-Loss Devices Medical Device and FDA Regulations and Standards News 0
D Measuring fine tubing (< 0.100") "Wall by weight" General Measurement Device and Calibration Topics 11
Q FDA 3500A Reports - Trip and Fall - Weight scale with a fold out platform Other US Medical Device Regulations 1
P Calculating a weight for a machine for the CE label CE Marking (Conformité Européene) / CB Scheme 0
M Informational US FDA final guidance Characterization of Ultrahigh Molecular Weight Polyethylene (UHMWPE) Used in Orthopedic Devices Medical Device and FDA Regulations and Standards News 0
Y How to fix weight tolerance for plastic injection molded part? Does it vary with material groups? Manufacturing and Related Processes 1
M Perform a coating weight test within 3 hours of processing the parts Manufacturing and Related Processes 2
A IMDS - Changing the Locked Weight Value RoHS, REACH, ELV, IMDS and Restricted Substances 1
N PFMEA Potential Failure Mode for Weight FMEA and Control Plans 5
J Calculating impact force, expressed in lbs, of a 5 lb weight dropped 48 inches Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A Calibration of Disposable Weight Scales General Measurement Device and Calibration Topics 2
R Weight Sets for Checking Table Balances Quality Assurance and Compliance Software Tools and Solutions 5
T Calculation Question - Calculate the runner weight for a part Manufacturing and Related Processes 2
T Calculating Plating/Coating Weight for IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
