should i be adjusting the process after every 10th piece measurement? I mean if it is going out of tolerance I would be adjusting it back to the LCL...today i faced a bit of an issue as the 1st 10 odd pieces started trending out below the lower specs...
You need to adjust when you hit your 75% of tolerance - no matter when that occurs.
If your tool wear should indicate the parts get bigger as the tool wears, but the parts got smaller, then what you are seeing is start up/warmup variation. This is why start up/warm up is a special cause. It is not stable until the process comes to equilibrium, and requires special attention during that time - including more frequent checks. You may need some patience to get to that point of steady-state process.
Did the process ever "settle down" during the run?
Have a strong belief there are a lot of special causes which need to be looked into before i carry this excercise again..agreed?
It is hard to say from a distance, but at least you are paying attention to the things that count now!!
my question though is - should i select line with max variance or min variance for this?
I suggest using the technique on a line with less variance to get used to it and learn how it works, then go the the line with more variance and use the tool to sort it out.
