Q
qcdirect07
Thanks for your fast reply! If I understand you correctly your saying that the threaded hole can still be good even if it won't accept the gage? Then what good is the gage?
I have seen this on many occasions. What happened here is that the Whitworth was originally an English system with imperial unit of measure. When the UK mandated conversion to the metric system, thread nomenclature was excepted and allowed to remain as an imperial designation for consistency, but the thread details were all changed to metric. Well as people worldwide designed new products the nominal major diameter was quickly changed to metric, but the threads per inch remained the same. Yes this does cause much confusion. I have also seen the same mix of measurements on ACME and Unified.For reasons that have been lost in time, many of their threads have a diameter in millimeters (mm) and a pitch in TPI. The mm diameter is in no way related to any relevant inch diameter. To make things even worse the thread is Whitworth with a 55 degreef lank angle.
Gordon, you were right to suggest that they designate the thread type. This is mandatory and for accurate product design, and can not be neglected now that they are using subcontractors to make their parts.Now to the problem. On their drawings these “strange” threads are given as, for example 60 x 12.... I suggested as a minimum, that their drawings specify thread type.... I discovered that tolerances, at best, were very vague... The $64,000 question is: Does anyone know if there is an approved method for dealing with these non-standard thread types and gages or even if there is a recognized calibration standard that could apply?
When I stated that the nominal major diameters quickly changed to metric, I did not mean an imperial converted to metric, I meant they just used the metric size that fit their need with no reguard to any imperial size.The diameters the company in question uses has absolutely no connection to any comparable (i.e. 1 inch = 25.4 mm)) inch dimensions. Still, BS 84 does allow for diameters “from” and “up to” on selected and non-standard threads,...
Silly you, you expect the engineer to read and follow the recommended from the standard?...although the TPI they use don’t always coincide with the recommended TPIs
