Restricted Scope of ISO 13485 Certification
KatieQA
Hey all - long-time lurker, first-time poster. I'm in the process of getting my IVD company ISO 13485 certified under MDSAP. We passed our Stage 1 with flying colors. Now it's crunch time for our Stage 2. We are considering restricting our scope to drop production for the time being. Here's the question I'm trying to answer:
When does a company *really* need their production certified? Is it:
-Prior to producing clinical study devices? (Or are those part of Design and Development?)
-Prior to first 510k and concurrent FDA registration (or is a Design and Development scoped cert sufficient for this)
-Prior to producing the first medical devices that will be sold?
Thanks in advance!
yodon
First off, separate FDA, IVDR, MDSAP, and 13485. While there's overlap, there are distinct differences.
FDA doesn't require 13485 certification. To enable distribution in the US, you only require clearance through the 510(k). They *may* accept the MDSAP audit results in lieu of doing an inspection (it's by no means a guarantee). FDA also requires that you register as a device manufacturer.
IVDR doesn't exactly require the company's QMS to be certified to 13485 - but it's the easiest route. To enable distribution in the EU, your product needs to be CE marked. That's a process of demonstrating compliance to the IVDR (and in which one element is that your quality system meets requirements - which is generally demonstrated by certification).
Premarket clinical studies are kind of odd ducks. I believe it's typical for those to be governed by an external body (e.g., IRB) and they may require specific safety or performance requirements be demonstrated prior to initiating the trial.
Circling back to your question: why would you want to exclude production "for the time being?" Expanding scope later just means additional audits.
KatieQA
All very good points, and helpful. We are considering excluding it because we are concerned we won't have sufficient evidence to audit by our audit date. For example, we won't have process or software tool validations complete. Functionally, for our medical devices, we will be in a design and development state until about our first surveillance audit a year from now. At which time, we could expand scope concurrent to the surveillance audit. (Perhaps of note - we have non-medical devices in production now, and are in the process of implementing our newly developed ISO compliant SOPs onto those products, but the process is taking longer than anticipated)
So if I'm reading your reply correctly, there is no specific regulatory requirement for timing of ISO 13485 cert with full scope, but it is helpful (perhaps very helpful) to have in place prior to FDA registration and CE mark. And may also be helpful for premarket clinicals depending on IRB, protocol, etc. Is that a fair assessment?
yodon
FDA doesn't consider 13485 certification. Your 510(k) has to have data which demonstrates substantial equivalence to the predicate. You do have to have a Quality System but you have to address the FDA requirements (which should have been covered in the MDSAP audit), not 13485.
For CE marking, having 13485 certification is, indeed, the easiest path.
I would talk to your ISO registrar about scope and timing. If you have a plan for completing those activities, they *may* accept. It's typical that not everything is fully in place (e.g., postmarket surveillance - actually implementing it - you do need the procedures). If you're not planning on marketing in the EU for over a year, you may want to postpone the Stage II (although they may require that the stage I be re-done). Definitely worth a call.
Sidney Vianna
Post Responsibly
I think the question you should ask yourself is: What would an ISO 13485 certificate WITHOUT PRODUCTION offer you? How would that benefit you? The CB is expected to scrutinize the scope of certification very carefully, as required in the IAF MD9 Document where it reads:
"...The CAB shall precisely document the scope of certification. The CAB shall not exclude part of processes, products or services (unless allowed by regulatory authorities) from the scope of certification when those processes, products or services have an influence on the safety and quality of products ..."
KatieQA
Good question - our goals include demonstrating the ability to meet the requirements to various stakeholders, internal and external; performing design and development under the standard (which admittedly could be done without a cert, but the cert ensures it is truly compliant, with less risk of "rework" or "back-fill" work generating the DHF after the fact); and laying the groundwork for a quick turnaround on transfer to manufacturing / saleable product when the development work is complete.
Open to feedback on the strategy if you or anyone has any thoughts to share
KatieQA
I should also add - we have other processes in place with evidence - e.g., management reviews, internal auditing, purchasing with supplier controls, CAPA, non-conforming material handling, incoming inspections, training, etc.
Sidney Vianna
Post Responsibly
I don't agree with the premise here. If you are interested in degree of conformity of the existing processes against ISO 13485, I would go with an assessment route. An audit just like a "certification audit" without the pressure, limitations and constraints of a certification audit.
Certificates with serious scope limitations almost always sound as a marketing ploy. Companies issue press releases boasting about their certificates, but NEVER mention that the certificates have limitations.
Good luck.
N Actor registration EUDAMED restricted: got no Email to complete the registration EU Medical Device Regulations 9
J Restricted device vs. prescription device Medical Device and FDA Regulations and Standards News 1
Q Restricted Substance in my Product - How to declare problem? RoHS, REACH, ELV, IMDS and Restricted Substances 3
F Statistical Models (Sigma - Restricted Vs Over- parameterized parameterisation) Statistical Analysis Tools, Techniques and SPC 2
Kales Veggie Ford RSMS (Restricted Substance Management System) 2008 released / GADSL categories RoHS, REACH, ELV, IMDS and Restricted Substances 16
M Restricted Plastic Material in the manufacturing of automotive parts? Customer and Company Specific Requirements 3
S Is Toluene (Methylbenzene) a banned or restricted substance Miscellaneous Environmental Standards and EMS Related Discussions 4
D GM's GMW 3059 - Restricted and Reportable Materials For Parts Specification Customer and Company Specific Requirements 4
P PSW (Part sample Warrant) - Restricted or reportable substances APQP and PPAP 13
S Recycling codes on PSW - Restricted or reportable substances APQP and PPAP 4
I Restricting scope to one part number for one customer IATF 16949 - Automotive Quality Systems Standard 6
A ISO 9001- any advise please with transitioning from a paper based system to eQMS and multi site scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S F-108 Request for Expansion of Scope of Accreditation ISO 17025 related Discussions 2
S Scope of management review ISO 13485:2016 - Medical Device Quality Management Systems 5
D Do all products fall under scope of AS9100? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M PROBLEM IN SCOPE OF ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
N ISO 13485 Scope Reduction Other ISO and International Standards and European Regulations 2
M AS 9100 Scope for Repair Station with PMA approval AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M Intended Use vs Actual Use and Scope of Risk Management EU Medical Device Regulations 8
Stefan Mundt Split Scope = Separate Audits ??? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
lisap Design falling outside ISO scope Misc. Quality Assurance and Business Systems Related Topics 11
A Scope of ISO 13485 certification as legal manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 4
R ISO 13485 certification scope ISO 13485:2016 - Medical Device Quality Management Systems 5
Q Kap.4.3 Determining the scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
B ERP software validation - risk assessment vs validation scope ISO 13485:2016 - Medical Device Quality Management Systems 11
G Why are 17025 scope angle measurements limited to 5 to 85 degrees? ISO 17025 related Discussions 2
3 Scope question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G Internal Laboratory Scope IATF 16949 - Automotive Quality Systems Standard 10
T How to handle out-of-scope activities. ISO 13485:2016 - Medical Device Quality Management Systems 7
Enghabashy Supply chain main policies ,scope, risk assessments & relavant KPI Supply Chain Security Management Systems 2
M Does the scope of ISO 9001:2015 applies to tenders, pricing and sales department of a medical devices distributor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Can outsourced processes be excluded from QMS scope? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
D IATF 16949 M&TE Laboratory scope IATF 16949 - Automotive Quality Systems Standard 7
J Informal vs formal scope creep... managing non-medical devices through system processes ISO 13485:2016 - Medical Device Quality Management Systems 2
R "Medical devices" required in scope ISO 13485:2016 - Medical Device Quality Management Systems 2
R CB/Auditor Requiring a change in scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D ISO 13485 scope (implantable) - Polymers for dental application EU Medical Device Regulations 9
M ISO 13485:2016 Certification Scope ISO 13485:2016 - Medical Device Quality Management Systems 4
M Scope for ISO 13485 Certification of a Translation Service Provider ISO 13485:2016 - Medical Device Quality Management Systems 19
H Implementing ISO22301 on a Limited Scope Business Continuity & Resiliency Planning (BCRP) 2
M How Specific in an ISO 13485:2016 Scope for a Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 9
Q The scope of ISO 21534 Other Medical Device Related Standards 0
A Scope of ISO 13485 certificate ISO 13485:2016 - Medical Device Quality Management Systems 1
K Medical Device Repairs and ISO 13485 Scope ISO 13485:2016 - Medical Device Quality Management Systems 7
K Software Updates in the Field and ISO scope ISO 13485:2016 - Medical Device Quality Management Systems 2
I IATF Lab Scope Testing Qualification and Competency Documentation IATF 16949 - Automotive Quality Systems Standard 3
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
silentmonkey Are risks in supply chain and development activities within scope of MDD? EU Medical Device Regulations 4
D Limited Scope for second site Question? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
