David Hartman
BTW: If I understand your original question, it appears that you are attempting to justify the amount of Pb by expressing its weight as a fraction of the overall weight of the flex. If this is the case, I believe that your premise is incorrect in that the RoHS requirement is for less than 1% by weight of the "homogeneous" materials. The European Commission’s own documented guidelines defines homogeneous as the individual components that make up a product, where if they were to be separated they would no longer exhibit their individual characteristics (i.e. solder, copper wire, enamel, etc.).
With this in mind the fact that 60/40 solder/tinning is being used already tells you that it is non-compliant in that the solder (a homogeneous material) contains greater than 1% Pb.
