Scope for ISO 13485 Certification of a Translation Service Provider
My company (Translation company) is starting the process of ISO Certification. Would anyone be able to advise what clauses in the standard are out of scope for a Translation company?
somashekar
Here is an attempt list and you have to provide the due justification for its exclusion / non application based on your nature of business...
Exclusion: 7.3
Non applicable: 6.4 / 7.5.2 / 7.5.3 / 7.5.4 / 7.5.5 / 7.5.7 / 7.5.9.2 / 7.6 / 8.2.3 / 8.3.4 /
DannyK
I agree with the list provided by Somashekar except for 8.3.4. A translation company may be asked to rework a translation job,
I personally would not exclude 6.4 -work environment .
Thanks for the replies folks.
One more question, we developed our own software system for translating document. When we get a document from a customer we use this system to translate the document into the language the customer requires. Does this system need to be validated?
somashekar
YES
Please read the 7.5.6 of the ISO 13485 for clarity on this.
Thanks and good luck.
LUFAN
That's computer system validation. Would fall under framework/guidance of ISO 80002 or future FDA "Computer Software Assurance for Manufacturing and Quality System Software" due out any day now.
I'm a bit confused. Do I need to follow ISO 80002?
LUFAN
You don't have to follow any particular document as FDA nor any regulatory agency as far as I am aware specifies to do so. However, it needs to be done in a manner which is structured and is risk based (13485). Sans use of any new documentation, the methodology for validation of most software programs used for QMS activities (under FDA scope) was based on a 2002 FDA Guidance. Of course, a lot has changed in the way of technology since then and while it's still relevant, its not all that practical any more. It essentially tells you to perform an IQ/OQ/PQ without calling it that. The problem with this method if essentially every single aspect of the software needs to be heavily tested and scrutinized with test cases. First one I ever did for eQMS was 130 individual test cases ranging between 5 and 200+ steps each. I want to say we had like 15/20 3" binders full of test cases and reports. Takes forever, extremely resource heavy, and a major burden, given that validation is needed before go-live and any subsequent change.
That's where 80002 came along. It essentially gave us another structure to follow which allowed us to apply risk to more important areas, test those more heavily, and others less. Did it eliminate massive amounts of paperwork? Definitely not, but not an insignificant amount either. 80002 is essentially 14971 for QMS software. This allows future validations to more structured around risk, rather than performing test cases of every single little thing, which would be expected during an OQ. Essentially before if you checked a box, you would need to validate it's performance; now you can perform a risk analysis to determine if checking that box, which might do something trivial, is worth testing at all.
Next up and not yet released is FDA's version of "Computer Software Assurance for Manufacturing and Quality System Software". Which will be essentially the same thing as 80002, formally repealing the 2002 guidance. This has been promised by FDA forever now, but it's allegedly due out this quarter.
Here's the ISO 13485 Practical Guidance document:
The validation of software is covered in different parts of ISO 13485 depending​
on the use to which the software will be put (e.g., for processes in the QMS,​
as an element of the product or as the product itself, for the control of production​
or service provision, or for monitoring and measurement). Throughout​
the standard, the requirements for validation of the application of computer​
software are consistent irrespective of the use.​
For guidance on validation of the application of software used in your QMS,
you can find additional information in ISO/TR 80002‑2.
The too long didn't read version of this is using 80002 will actually save you time and is still an effective way to perform validation. Until FDA's new guidance is published, I would select 80002 every time.
D ISO 13485 scope (implantable) - Polymers for dental application EU Medical Device Regulations 9
M ISO 13485:2016 Certification Scope ISO 13485:2016 - Medical Device Quality Management Systems 2
M How Specific in an ISO 13485:2016 Scope for a Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 9
A Scope of ISO 13485 certificate ISO 13485:2016 - Medical Device Quality Management Systems 1
K Restricted Scope of ISO 13485 Certification ISO 13485:2016 - Medical Device Quality Management Systems 7
R Scope of ISO 13485 certification ISO 13485:2016 - Medical Device Quality Management Systems 6
P Dropping ISO 9001 limits the scope of the ISO 13485 audit? ISO 13485:2016 - Medical Device Quality Management Systems 6
S ISO 13485 scope of certification - We are a virtual manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 1
K MDSAP scope vs ISO 13485 Scope Canada Medical Device Regulations 4
R Scope of Certification for a Design Organization with Outsourced Mfg. - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 10
M OEM-OBL ISO 13485 Certification - Devices mentioned in the product scope ISO 13485:2016 - Medical Device Quality Management Systems 4
chris1price What are the Scope Numbers on ISO 13485 Certificates ISO 13485:2016 - Medical Device Quality Management Systems 2
R ISO 13485 Certificate Scope modified by Notified Body EU Medical Device Regulations 9
S What is the scope of EN ISO 13485 and ISO 13485 ? ISO 13485:2016 - Medical Device Quality Management Systems 3
A Scope of ISO 13485 Registration and Component Makers ISO 13485:2016 - Medical Device Quality Management Systems 7
D Scope of ISO 13485 Certification needs the word Production. ISO 13485:2016 - Medical Device Quality Management Systems 9
V ISO 13485 certification scope in Spanish ISO 13485:2016 - Medical Device Quality Management Systems 5
N Scope of ISO 13485 Certificate for Multiple Devices EU Medical Device Regulations 3
B Class IIb Medical Device using Annex II route - Need to Update ISO 13485 Scope? ISO 13485:2016 - Medical Device Quality Management Systems 2
L Non-medical device is in the ISO 13485 audit scope? ISO 13485:2016 - Medical Device Quality Management Systems 11
Ajit Basrur Scope for ISO 13485 vs. ISO 15378 - Molding Parts for Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 4
Q The scope of ISO 21534 Other Medical Device Related Standards 0
K Medical Device Repairs and ISO Scope ISO 13485:2016 - Medical Device Quality Management Systems 3
K Software Updates in the Field and ISO scope ISO 13485:2016 - Medical Device Quality Management Systems 2
J Scope of ISO 9001 clause 10.2 in the product life cycle ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M ISO 27001 ISMS scope for companies with subsidiaries IEC 27001 - Information Security Management Systems (ISMS) 0
L Dying a slow SCOPE death - NEW ISO APG Paper on Scope and Applicability May 2020. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P ISO 80369-7 standard - Interpreting which Parts should be in scope Other Medical Device Related Standards 7
I Sales Documents in scope for ISO-9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
qualprod ISO 9001:2015 8.5.1 f - Scope with customer special process requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S ISO 9001:2015 - Scope of Registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 35
N ISO 9001 certification with limited scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q ISO 9001, section 4.3 Determining the scope of our QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q ISO 9001:2015 - Extent of Policy and Scope with Context and Interested Parties ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K ISO 9001:2015 clause 9.2.2 a. - Define the audit criteria and scope Internal Auditing 2
B ISO 14001:2015 4.3 - How to make the scope of the EMS available to interested parties ISO 14001:2015 Specific Discussions 4
F ISO 9001:2015 4.3 - Determining the scope of the quality management system ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J ISO 17025, Laboratory Scope and Certifications Requests ISO 17025 related Discussions 4
G How to define the scope of QMS as per ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
Anerol C IATF or ISO TS 16949 rules about Scope of QMS IATF 16949 - Automotive Quality Systems Standard 7
M Taking on a job outside of our ISO Scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
I ISO 9001 Scope - Exclusion of Design in an engineered solutions company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
T Does your Quality Dept Control Procedures Outside the Scope of ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S ISO 9001:2008 Certification Scope does not mention "manufacturing" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
F ISO/TS 16949 internal audit scope and annual plan Internal Auditing 2
F What is the scope for "Total Numbers of Employees on site" per ISO/TS 16949 ? IATF 16949 - Automotive Quality Systems Standard 4
R Changing ISO 9001 Certification Scope Quality Manager and Management Related Issues 4
