SQCPack SPC Software Subgroup Size to Small
Brad Gover
Hi all, my company uses SQCPack version 6.0 software made by PQ Systems. I need to have a subgroup size of 216; however, the program only allows for a maximum of 40. I need n = 216 because we have 54 blind holes in a disk. Each disk has 4 tabs in it thus 216. My variation is not within a blind hole; but, across the entire disk (holes 1 thru 54). Any luck overcomming the limit of n = 40 max?
Thanks for any help
Brad
It is highly unlikely that you need a subgroup that large. First, you need to determine the rational subgroups. You have at least two choices:
  1. Within hole variation forms the subgroup. Subgroup size = 4.
  2. Within disc variation forms the subgroup. Subgroup size <= 54. You do not need to measure all 54 holes to have a good representation of across disc variation. 5 would check 4 quadrants and the center. 7 would check every 60 degrees and the center, etc. Are specific hole sizes repeatable from disc to disc? You may have 54 process streams.
You apparently are not concerned about within hole variation. Are you concerned about hole to hole variation within a disc? From disc to disc? Your answers to these questions should be used to establish your subgroups.
Matt33
Brad,
I am sure you meant to do the following: Create the characteristic with a Sample size (Subgroup size) should be entered = 1.
The number of subgroups or samples (not the subgroup size), can be 216 or any other number. There are no known limits on the number of samples that SQCpack allows you to enter and/or chart.
Or, as the other poster, Miner, indicated, the Sample size might be 4 with 54 rows or 54 samples of data.
PQ Systems SQCpack Tech Tuesday Webinar 3-Part Series Using SQCpack Software 0
PQ Systems SQCpack Tech Tuesday Series Using SQCpack Software 0
PQ Systems Data Entry Workflows with SQCpack Using SQCpack Software 0
PQ Systems Device Integration with SQCpack - 3 Part Series Using SQCpack Software 0
PQ Systems What's New in SQCpack 8 Using SQCpack Software 0
PQ Systems SQCpack 101 Using SQCpack Software 0
S Process Monitoring using SPC software Quality Assurance and Compliance Software Tools and Solutions 3
B Wrong standard deviation calculation in AIAG SPC manual? Capability, Accuracy and Stability - Processes, Machines, etc. 13
K Sr Process Engineer (Hillsboro, OR) - SPC Program Focused - Ultra Clean Technology Job Openings, Consulting and Employment Opportunities 0
D Locking Control Limits and SPC Sample Sizes (AIAG/Automotive Requirements) Six Sigma 2
D SPC procedure Statistical Analysis Tools, Techniques and SPC 5
PQ Systems Scaling Up? Don't Leave SPC Behind Using SQCpack Software 0
PQ Systems 5 Costly Mistakes to Avoid When Applying SPC Using SQCpack Software 0
J Spec Limits in SPC charts Statistical Analysis Tools, Techniques and SPC 24
G Need journal and reference of abnormal bar chart SPC Statistical Analysis Tools, Techniques and SPC 4
Q CQI-26 SPC Short Run Supplement Capability, Accuracy and Stability - Processes, Machines, etc. 1
A SPC procedure / flow chart Statistical Analysis Tools, Techniques and SPC 2
P Informational SPC in Batch Processing Statistical Analysis Tools, Techniques and SPC 3
A How to reduce the process SPC monitoring Capability, Accuracy and Stability - Processes, Machines, etc. 3
P SPC for machining processes Capability, Accuracy and Stability - Processes, Machines, etc. 1
J SPC - Stamping parts - Small batch size Statistical Analysis Tools, Techniques and SPC 6
S Anyone Familiar with "SPC for Excel" add-in? Lean in Manufacturing and Service Industries 4
G Assignable cause/corrective action list for SPC Software Statistical Analysis Tools, Techniques and SPC 3
H SPC for special characteristics - CSR - Control of SC and CC Statistical Analysis Tools, Techniques and SPC 1
L SPC - Methods to collect data IATF 16949 - Automotive Quality Systems Standard 7
Marc Steve Prevette's Statistical Process Control (SPC) "Library" Statistical Analysis Tools, Techniques and SPC 0
A SPC for Eddy Current Testing Statistical Analysis Tools, Techniques and SPC 28
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
Proud Liberal Informational Use of Classical SPC in Precision Machining Statistical Analysis Tools, Techniques and SPC 9
J Recommendations on Inspection/SPC Software Statistical Analysis Tools, Techniques and SPC 4
Q Real Time Electronic SPC/Control Charting Statistical Analysis Tools, Techniques and SPC 4
Rameshwar25 Other types of Control Charts described in Chapter II of SPC Manual Statistical Analysis Tools, Techniques and SPC 6
A Electric terminal crimping machines - Is SPC appropriate for this process? Manufacturing and Related Processes 4
J Properly understanding SPC - Newbie SPC questions Statistical Analysis Tools, Techniques and SPC 34
bobdoering SPC Charting frequency calculator for X hi/lo chart Imported Legacy Blogs 0
bobdoering Handy training tip for SPC - the Check Engine Light Analogy Statistical Analysis Tools, Techniques and SPC 0
QMMike SPC Software for MAC computers Statistical Analysis Tools, Techniques and SPC 2
Marc SPC based Dashboards - By Steve Prevette (November 2017) Statistical Analysis Tools, Techniques and SPC 1
H SPC Work Instructions (WI) Statistical Analysis Tools, Techniques and SPC 2
S Doubts about SPC taken in Machining - Part has +-0.01 Tolerance Statistical Analysis Tools, Techniques and SPC 5
E SPC for Dummies - The correct meaning of all the graphs Statistical Analysis Tools, Techniques and SPC 3
Tagin Can/should SPC be applied to Computer Assembly and Software Imaging? Statistical Analysis Tools, Techniques and SPC 8
