My company is considering the purchase of a Romer 7520 arm (2m range) for one of our plants to use for machine setup/alignment (non-critical) and some inspection. In their literature the repeatability is quoted to be +/-.016mm and accuracy +/-.023mm and certified per B89.4.22.
Shouldn't the true reported repeatability be .032 and for accuracy .046, for example measuring the distance between two holes? Wouldn't the uncertainty be the sum of those? I find the +/- to be a bit misleading.
Our other plant had a demo performed and the plant manager is sold on the machine. My plant currently has a smaller manual CMM. I obtained a quote for a larger DCC CMM as we do different types of work than our sister plant. Rumor has it however, that instead of upgrading it to a newer DCC CMM, some are suggesting the Romer could replace the CMM for inspection.
I am having deep reservations about this because we routinely measure machined details with TP of .030, concentricity .013, perp .013, diameters <.025 tolerance and so on (metric).
In a meeting I brought up the accuracy issue. The quoted DCC CMM has a MPEe= 3.2 + L/300 accuracy and MPEp=3.2. which would suit most of our needs and provide greater throughput. The probe system is the PH20 with TP20.
The supporters of the Romer say the machine is more accurate than the spec when measured at closer ranges which is believable, however since Romer does not offer an accuracy statement for that, how can it possibly be known what the accuracy/repeatability is throughout the measurement range? Admittedly I've never used an articulating arm and do realize the advantages of them, however some tell me they are not well suited for close tolerance measurements, and since Romer only quotes the total volumetric error, how reliable can the measurement be? I don't think it should be any less than the stated accuracy in their documentation. If they are are much more accurate in the smaller envelope, than where is the cert to prove it? What do you do, measure the feature until it falls in tolerance and accept it as good sarc/off ?
Using the 4:1 TUR (test uncertainty ratio), I can't imagine ever trusting an arm to measuring with any confidence closer than +/-.13mm tolerance.
Anyone out there that can give me some insight into this would be greatly appreciated as I'm afraid by purchasing this arm my plant may be making a big mistake, but could be wrong.
