eldercosta
While reviewing subclause 15.4.3 I had the following question regarding the subclause below.
I have two Manganese Lithium batteries (size 621) in my design. They are only used as backup power of RTCs/CMOS RAMs. The cells are soldered on board and the charging circuit follows the manufacturers guidelines (charging voltage 3.3V through a small signal schottky diode and proper series resistor to avoid overcharge).
Though technically these coin cells would fall under the secondary lithium definition (according to the subclause above), I am under the impression these cells are out of the scope. Two manufacturers (Panasonic and Seiko-Epson) do not state IEC 62133(-2) compliance (at least I could not find any reference to this compliance) which suggests it is not required for the typical application of these cells. FWIW, the amount of Lithium in these cells is very low (2mg according to Panasonic, 3.2mg according to Seiko), so I guess most of the concerns of Li-Ion cells do not apply either.
I don't have the full 62133(-2) standard here I only saw the samples of it, including the scope and the index and they did not provide enough info to determine it is applicable or not. I may order if it turns out to be really necessary.
So, do these cells fall in the scope of IECthese standards?
Thanks in advance.
15.4.3.4 Lithium batteries
Primary lithium batteries shall comply with the requirements of IEC 60086-4. Secondary lithium batteries shall comply with the requirements of IEC 62133 or IEC 62133-2. See also 7.3.3.
NOTE Batteries includes both single cells and assemblies of cells, i.e. battery packages.
Compliance is checked by inspection of the battery design documentation or by performance of the tests identified in IEC 60086-4.4 for primary lithium batteries and IEC 62133 IEC or 62133-2 for secondary lithium batteries.
Thanks in advance.
