The calibration COULD be performed. It would consist of six LVDTs that would have to be removed from their housing, put in to our calibrator, which has a resolution of 0.0001 mm, have linearity verified, and then put back into their housings, and all be reset this while also grappling with the downtime affect of production. I understand that either way you do it, production is going to be affected. I just wanted to question the validity of this method and whether or not it would be against IATF 16949. When I was first told that this is how we were doing this, I was a little taken back because we have traditionally always performed calibrations or at least linear verifications on gauges like LVDTs. Once I understood that we were just using a verified master that is verified and used to set the machine annually, coupled with the fact that we only run one part in that machine, it seemed to make a little more sense. Even when I explained this to the auditor recently, he seemed to except the method, which was great, however, I’m not 100% convinced that, this is acceptable by the book.
