What is the characteristic and how does the characteristic affect the function of the assembly it goes into, or if it's a stand-alone part how does the characteristic affect the function of the part?
There must be a reason why you've decided to make this measurement. My assumption is that you're concerned that the part may fail under stress, whether in an assembly or by itself in use. Simply setting a specification based on what you're receiving for product currently may control the problem of failures, but without a logical reason that the specification should be at a particular level, you may end up rejecting parts that for all intents and purposes will function perfectly simply because they're not quite as good as what you started with.
For example: parts you receive are tested and sustain a torque force of 500 foot/pounds. After engineering experimentation, you determine that for your application, they need to sustain a minimum torque of 200 foot/pounds. Are you going to reject the more recent parts simply because they test at 400?
My suggestion is to get engineering involved and figure out what you need to make the part work without failure, then make sure your supplier can provide you with a process that is capable to make them.
