Where to begin with an ISO 9001:2015 internal audit
Our very small manufacturing company is new to ISO 9001:2015. We need to plan and complete our internal audit but are clueless as no one here has done this before. Do we have to audit every Section of the QMS from 4.1 to 10.3? Or can we choose a few processes/areas of our business and audit those? For example:
1. Audit purchasing process and procedures
2. Audit a particular part we manufacture and trace it back to customer order
3. Audit tune and test procedures
Would auditing 3 key areas of operation suffice? We just don't know where to begin!
Ninja
Looking for Reality
Howdy, and welcome to the forum...
FIrst, do a search on this forum...there are a TON of answers to this question lying around here...
Second, if no one there has ever done an internal audit, I strongly recommend you contract out your first year (or three).
Have your QM, or someone who will be leading your IA team later go along with the internal audits to learn by experience.
There are a number of things you can pick up and figure out for yourself...but IA is rarely one of them. Hire an old pro at it and learn by watching. It will cost you less in the long run...
And MAKE SURE you tell whomever you bring in that you've not had an internal audit before...that's a horrible thing to surprise someone with...and it will likely be a negative experience for both sides if you don't give fair warning first.
Coury Ferguson
Moderator here to help
Are you having a 3rd Party Registration Audit in the very near future? If it is, delay it. Apparently you wouldn't be ready. This would be found during Stage 1 of the external/registration audit.
To answer your question in a more direct manner: You audit the processes not the paragraphs. You want to see the interaction of those process. You would need to make sure you meet all of the requirements of ISO 9001:2015. Selecting 3 key processes only would miss the mark.
As Ninja stated, it would be better to have an outsider of the organization run a few Internal Audits. Take a class on Internal Audits (you can look at ISO 19011 to help guide you).
Just my opinion.
Golfman25
So generally prior to your certification audit, they will want to see a full internal audit of all processes. I agree with Ninja, if this is your first experience you should have a consultant do your first series of audits and shadow him, or go to an internal (not external) audit training course -- sometimes a local trade association might put one on.
Over time, I have found creating checklists based on the process ensures my auditors hit all the key points I want them to hit. Kind brings it down to "auditing for dummies" and works for small organizations.
Mike S.
Happy to be Alive
With a brand new system the first thing I'd do is verify that somehow, in some way, I have adequately addressed every single requirement (shall) in the standard, and do it well before it is time for the 3rd party auditor to show up. Part of that means a complete internal audit cycle needs to be completed and any noted nonconformances addressed.
Later, you schedule internal audits based on "the importance of the processes concerned, changes affecting the organization, and the results of previous audits".
If you have no trained internal auditors, as someone said, that is a competence issue you need to address.
RoxaneB
To add to the responses already provided, I usually employed one of two strategies:
1. Start with Leadership/Top Management - Since they're already in the room (presuming you're doing an opening meeting), this saves them from having to come back later. It's also a good way to hear what they think the QMS is all about and how they think it's doing/working. From there, as the audit expands out, I'm continually looking to see alignment between what leadership says/does versus what the rest of the organization says/does.
2. Final product walk-thru - We would select a product that was about to be shipped (i.e., sitting on the truck at the scale and about to be processed). From there, we worked backwards. We still asked about current processes, but following that one item back was a good exercise for traceability and records.
John C. Abnet
Teacher, sensei, kennari
Good day @Willhele007 ;
Obviously you have already received some great council in this thread. It has been assumed that your organization is "just starting" and preparing for initial registration . Please advise if that assumption is correct.
Specific to your question, the standard does not specify a frequency, but allows/requires the organization to determine frequencies based on "importance...", "changes...", results of previous audits....", BUT if this is your organizations initial preparation for 3rd party registration, then it is important to include all processes for a full "round" of audits.
One thing that I have done for "new" teams in the past is as follows...
a) Create a matrix with each of your organizations determined processes (e.g. Buy ingredients- Assemble Pizza- Bake- Cut- Deliver) across the top of the columns.
b) Associated with each of the process columns, identify the aspects (clauses) of the standard that apply to each of those determined processes
c) Now consider and confirm the items in "b" when you are auditing the processes in "a'".
While check lists can certainly be helpful (especially for new auditors), ensure your people are taught HOW to audit before they look at the checklist.
e.g.: To the auditee (process owner),.... "what are you doing?", "why are you doing it?" "how do you know what to do?", "how do you control what you do"? , "how do you manage changes to what you do?" "how do you know how well you're doing (i.e. what's the score) "?
....THEN the auditor will have a clear understanding of what is and what is not being taken care of by the auditee and now the auditor can refer to the checklist as a safety net to make sure nothing was overlooked..
As mentioned above, focus on YOUR organization's processes and reverse engineer the expectations into the audit plan.
Hope this helps.
Be well.
We are a small manufacturing company also. If we outsource the internal audit process, Would we need to hire the external provider (e.g. consultant), during a 3rd party audit?Or the internal audit records would be enough for the external auditor?
John C. Abnet
Good day @Danyboy32 ;
Your would not need to have your consultant present during the 3rd party audit. Even if the consultant was present, you would still need to provide evidence of your internal audit records.
Hope this helps.
Be well.
John
Hope this helps.
Be well.
John,
This is actually our third year of certification. We have passed for 2 years without knowing or understanding what we are doing. Our auditors have been tough on us- we did not get a pass either. There is nothing out there to fully explain the process in a concise way- and believe me I have looked. External auditors assume that we already know how to do an internal audit. It seems to me that year after year the internal audits will be redundant if you only have a handful of products. Am I wrong to make this assumption?
G New to ISO 9001 - Where to begin? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
J Where to begin to move our company towards ISO 9001 certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
F Where do I begin for ISO 9K:2K? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
supadrai Forced into Regulatory Affairs Role - Where do I begin? Career and Occupation Discussions 4
F Where does Contact begin for Biocompatability? EU Medical Device Regulations 5
N Where to begin defining and monitoring Quality Metrics in a Machine Shop Manufacturing and Related Processes 9
J Risk Management - Where to begin? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 21
T Implementing a Kaizen Team - Where Should I begin? Lean in Manufacturing and Service Industries 7
R MSA (Measurement Systems Analysis) - Where to begin when setting up a system? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
GStough Where to begin - creating a Quality Plan for Class I Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 7
H Auditing Lean as a process - Where to begin? Internal Auditing 9
T Changing Existing Quality Culture/Program - Where to Begin? Misc. Quality Assurance and Business Systems Related Topics 5
M Quality program, where to begin? One man machine/mold shop Quality Management System (QMS) Manuals 13
C where 2 begin? Info Mgmt Blueprint for internal Communication & knowledge xchange Document Control Systems, Procedures, Forms and Templates 3
CarolX Where does Quality begin? Philosophy, Gurus, Innovation and Evolution 36
M Research and Development Process - Where does research end and development begin? Misc. Quality Assurance and Business Systems Related Topics 15
J UDI - Where to document it? EU Medical Device Regulations 8
J Where to get a Black belt certification ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 13
D Any recommendations on where to find experienced quality hires in Chicago area? Job Openings, Consulting and Employment Opportunities 3
J Where is the definition of a critical supplier? ISO 13485:2016 - Medical Device Quality Management Systems 5
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
B When Travel is allowed - Where are you going? Travel - Hotels, Motels, Planes and Trains 16
G Where to buy Template / sample SCSMS Manual, checklist Supply Chain Security Management Systems 1
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
C Where to draw the line for "sufficient evidence" to verify safety/performance of a device? CE Marking (Conformité Européene) / CB Scheme 2
L Where to place the what/when/how/who/where procedures in a multi-regulation AS9110C organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B Where to acquire EN 868-5 required dye (Amaranth red)? Other Medical Device Related Standards 2
N Where to find Regulations for Reprocessing and Reuse of Single-Use Devices Other Medical Device Related Standards 2
H Where to get EK MED 1927/16 Other Medical Device Regulations World-Wide 3
D Where to find Guidance Class II Amendment Canada Medical Device Regulations 1
O EN 301 489-1 and EN 301 489-17 - Where do we get the information of the Published versions? CE Marking (Conformité Européene) / CB Scheme 1
A AS9100 Training - Where do I start? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
qualprod Records where apply and stop recording everything? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Where to place CE/label in Sterile IVD EU Medical Device Regulations 1
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 39
K No IFU, where the requirements would go? EU Medical Device Regulations 5
T Assessing Hazard-Related Use Scenarios where control measures exist through standards IEC 62366 - Medical Device Usability Engineering 32
J Where to Place Process Maps in our Documentation? Process Maps, Process Mapping and Turtle Diagrams 4
GreatNate Where to get a KPI dashboard for QMS processes Quality Tools, Improvement and Analysis 5
A Implementing ISO 20000-1 - Where to start Other ISO and International Standards and European Regulations 2
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 29
qualprod Statistics - Where to start in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H Calibration of InfraRan Vapor Analyzer - where to get calibration for SF6 General Measurement Device and Calibration Topics 2
M Where can I find examples of PPAP? APQP and PPAP 6
A What if Contract Manufacturers does not have an ISO 13485 certificate? Where will the NB audit take place, at legal mfg. site or contract mfg. site? Other Medical Device Regulations World-Wide 3
