Jim Biz
Energy:
Great minds work in similar pathways
We have used the same programming here - and found nothing to fault "the programming" for...
It does what it says it does
Our "USE" difficulity turned out to be - it did not make a good "fit" in our particular "cultural environment"...
Our upper level folks found that the Paretos, reports & such that we use in "spreadsheet format" did what they wanted them to do... (turned out that only one license was intended to be purchased & I already had a record set-up in excel. Without "over explaining" - I found that I was simply inputting the same info we had either on paper - or in excel into another (duplicating) programming format.
My take on it was - that IF it is not to be used by "multiple users"
(as was the case here) the time saving improvement (value) - was not high enough to spend the extra time on it.
