Hi greetings.
I'm not sure if this is the correct forum to post this question:
Relating to position tolerance, most of the literature I've found just use a plate with holes that pass through all the plate, but what if I have different holes on each opposite sides of the plate that don't go through all the depth of the plate? How will datums be specified since you have to "flip" the plate to dimension the holes on the other side?
Any examples you may have?
I appreciate it.
I appreciate it.
