Re: Management Review
2. Can we use the terms 'Planned interval' in our documented procedure instead of specifying that management review will be done on a quarterly basis? Will it not an issue if for example in one year we conduct 4 MRM and other year we conducted 2 MRM and following year only one MRM in case we use the term 'Planned Interval'
3. Please advise whether we should specify the agenda items which will be discussed during a MRM in the documented procedure?
FYI - If you would have asked me a few months ago on your questions #2 and #3 I would have thought this would be okay...
At our last
surveillance audit we received a minor nonconformity against ISO 9k clause 5.6 for using the term planned interval without specifying what the planned interval was or the items to be covered.
For reasons that are too long to explain in this post...We wanted the flexibility to have a management review meeting that only covered internal audits, with the intent that the next meeting would be a full meeting and would cover all of the required inputs.
Our CB explained that breaking the management review up into smaller meetings that did not cover all the required inputs was not the problem.
NC Evidence cited by our CB was:
that there was no objective evidence of planning, how many meetings and what had to be covered was not specified one Management Review covered all points and a later one did not (special meeting to review results of audits)
Our plan to correct the issue was rather simple, we adjusted our documentation to specify that:
"The inputs (we listed the required inputs) to the mgmt reviews are reviewed at least twice during the year and that this can occur as two meetings or several meetings during the year as conditions warrant.
The mgmt review records are used by the MR to track inputs covered at each review to ensure effective coverage of said inputs at least twice a year." (this is what we were doing anyway, we just did not state this in our documentation)
That plan to update the documentation along with a scheduling a follow up internal audit on the process to review the plan's effectiveness resulted in the plan's acceptance by our CB
Thought I would share what worked for us, in the hopes that someone else can avoid the embarrassing oops I stumbled into.
Regards,
Brunetta
