H
Help Me
OK. I'll bite. (I almost made it a full 24 hour without breaking my self imposed moratorium on posting).
How does the severity of a wheel falling off ever change?
IF it falls off, it falls off.
Just as an aside, a few years ago, there was a jet that crashed. It was determined upon investigation that what had happened was that an engine blade came loose and cut through the primary and the two or three back-up hydraulic lines meant to provide control to the tail sufaces used to control the flight of the plane.
Now, I am sure that you could say that the original severity ranking for the effect of the main hydraulic line failing was decreased by the addition of the secondary and tertiary hydraulic lines. But, in the big picture, shouldn't the severity ranking of last redundant hydraulic line have inherited the high severity ranking for effect of potential failure: Loss of control surface articulation, if you will.
This real world, actually happened, example, I think, illustrates my contention that you don't really reduce the severity ranking with a design. Whether it is a safety razor, or a space shuttle.
Yes, I think in terms of systems. I think it is a bit naive to not think in terms of systems. I really believe that the low hanging fruit and the biggest bang for the buck(pardon the gratuitous usage of cliche) is in focusing on design changes that will reduce the occurence and detection rankings.
Obviously my focus on a system FMEA is incorrect as no responses have echoed my stance.
Many thanks for your tireless (not intended as a pun related to the lugnut issue) efforts to explain the logic to me.
