The tolerance for the test coils that are used daily is +/- 100 lbs and they weight anywhere from 30,000 to 70,000. We have multiple scales throughout the plant that are checked with coils that we had verified by an outside certified source to determine the actual correct weight.
The finding was that we neglected doing these checks on a certain shift so it really is not a reason for tightening the tolerance however the management team believes we should tighten it up now that this issue arose.
We do not want to over or under ship coil weights to customers and there is a general consensus of +/- 1% in the steel industry. This means that for a 50,000 lbs coil they are guaranteed +/- 500 lbs. To me this seems excessive but it is a generally common industry standard or practice at most mills.
Sean,
Customers accepting plus or minus 500lb and you weighing to plus or minus 100lb is right for your industry.
Do your customers check weigh to a greater accuracy? Do your competitors offer greater accuracy? These are the only reasons for narrowing the range. But narrowing the range of mutually acceptable measurement would probably require a more capable weigh-scale.
Making up for a missed check with a tighter tolerance makes no sense from the information you have provided. Determining the economic frequency of calibration and those verifications makes more sense to me.
The shift that missed a verification may be trying to tell you something. They may know it is too frequent. Or they may ignore other requirements. This is the area to investigate further to see what is going on and determine a course of action.
It may however mean a manager would have to work the late shift!
John
