7.5.3.2 Traceability - How much traceability is required?
Matthies
Dear all,
For the medical ISO 13485 our company wants this certification.
But how much traceability is needed?
We configure computers to orders for hospitals.
(e.g. If we need to place a hard drive, we put a sticker on it that will be linked to the HD model and type. but is it needed to link the HD serial number with the sticker we put on it?)
:thanx:
SuperGirl
Re: 7.5.3.2 Traceability, how much traceability is this required?
It depends. Traceability mean that you know or can find out exactly where your product is, fairly quickly, if needed. If you can no precisely where it is without linking the serial number then no, but if you can't located it (fairly quickly) then yes you will need to.
Ronen E
Problem Solver
Moderator
It's a matter of risk management. List down what could go wrong if you don't enhance your traceability beyond what you currently have; how likely it is to happen; and what could be the consequences (for any stakeholder). Then assess the risk against the cost of implementing enhanced traceability, and against your statutory / regulatory obligations.
As an example, if your HD supplier notifies you one day that a certain batch of HD has a flaw that will cause X, what will be the consequences for devices in service? Will you be able to track their locations in case you decide to initiate a replacement? Etc.
Cheers,
Ronen.
Mark Meer
Well said. It is essentially a balancing act, and up to you to weigh worst-case probabilities and consequences versus the overhead to trace. It'd help to consider the worst-case that a recall is required:
For example, you could decide to completely relax traceability on the HD. If in the future, however, there is a known issue with a certain batch of HDs, with potentially catastrophic results, you would have to recall ALL devices as you'd have no idea which ones went into which devices.
On the other hand, if you evaluate the probability of this scenario as totally remote, then relaxed traceability might be justified. ...ultimately your call.
Matthies
Thanks all! We have implemented traceability for HDD with S/N in our system to prevent catastrophy in worst case scenarios :)
Now i do have some other questions,
if we use a certain glue or cable ties in the assembly process, is glue/cable ties needed to be in BOM?
And what about the boxes we pack our systems in, the tape we use, the pallet we stack the systems on... does that also need to be traceable? :bonk:
thanks!
Ronen E
Problem Solver
Moderator
thanks!
My opinion is that everything that goes into the device itself should be on the BOM, so yes - glue and cable ties should be there.
Regarding what needs to be traceable - it's as I noted befroe: assess the risk of not having it. I assume the risk in not having pallet traceability is quite negligible in your case.
Cheers,
Ronen.
Mark Meer
Once again: what Ronen E says.
All comes down to you assessing the potential risk first and foremost to the end user, and secondarily to your company.
Conceivably you could have a bunch of packaged (taped) units in inventory and discover that the adhesive from a certain tape order was old and doesn't hold the boxes shut properly. You'd then have to re-tape all the boxes... Is this a big deal? Is it probable? Probably no & no...
My feeling:
HDD: Traceable
Glue and Ties: On BOM, but no need for full traceability
Pallets & Tape: Unless packaging is critical in some way, don't worry about these...
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S Traceability of requirements to design and risk Design and Development of Products and Processes 3
T ISO 9001 8.5.2. - Identification and traceability to Identify Outputs - Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S IATF 16949 - Partial traceability of Aftermarket products IATF 16949 - Automotive Quality Systems Standard 5
R DHR question: Traceability of components ISO 13485:2016 - Medical Device Quality Management Systems 2
A Does AS9100 require traceability to operators performing the work? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Traceability of component parts - Bolts, screws and washers ISO 13485:2016 - Medical Device Quality Management Systems 3
R Traceability on Unmarked Parts - AS9100 requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T Non conformance product identification and traceability 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
B Traceability of Thermoelement Batches ISO 17025 related Discussions 7
G ISO 17025:2017 Uninterrupted chain of traceability for test laboratories ISO 17025 related Discussions 6
J What is the minimum standard for automotive component traceability? Manufacturing and Related Processes 2
A Validation of Calibration Methods and Traceability - ISO 17025 ISO 17025 related Discussions 3
shimonv Design input/output traceability for mechanical parts ISO 13485:2016 - Medical Device Quality Management Systems 13
K Identification and Traceability with an ERP system - Barcode Labels? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B PED 2014/68/EU - Is this Traceability audit finding correct? Other ISO and International Standards and European Regulations 4
N FDA Traceability Requirements - Component lots ISO 13485:2016 - Medical Device Quality Management Systems 2
Stefan Mundt ISO 9001:2015 - 8.5.2 Identification and Traceability Manufacturing and Related Processes 14
S How to maintain a design traceability matrix ISO 13485:2016 - Medical Device Quality Management Systems 2
N Requirements for the identification and traceability of demo product for sales force US Food and Drug Administration (FDA) 1
MrTetris Traceability in Medical Sofware Development Process IEC 62304 - Medical Device Software Life Cycle Processes 3
M Medical Device Traceability ISO 13485:2016 - Medical Device Quality Management Systems 9
G Where to list chain of traceability? ISO 17025 related Discussions 6
A AS5553B Counterfeit Prevention - Traceability requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
T In house Calibration? Measurement equipment traceability requirements - ISO9001 General Measurement Device and Calibration Topics 12
R ISO 9001:2015 Clause 7.1.5.2 - Is Measurement traceability applicable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Medical Device Traceability Matrix - Examples EU Medical Device Regulations 8
DeeDeeM IATF16949, clause 8.5.2.1 Identification and traceability-supplemental IATF 16949 - Automotive Quality Systems Standard 1
DeeDeeM IATF 16949 - Clause 8.5.2 Identification and Traceability IATF 16949 - Automotive Quality Systems Standard 7
D IATF 16949 - 8.5.2.1 Traceability Plan - Does anyone have an example? IATF 16949 - Automotive Quality Systems Standard 4
A UDI - Traceability of Products Other US Medical Device Regulations 1
B AS9100 Rev D - Traceability of Consumables AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Customer Identification and Traceability in Manufacturing Plans Manufacturing and Related Processes 5
S Traceability and the initiation of GMP Activities 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
N Calibration Traceability - Fluke 753 dpc with thermocouple Calibrated by Fluke ISO 17025 related Discussions 4
T Policy or Good Guidance for a Traceability Decision Tree (Serial and Batch Numbers) Misc. Quality Assurance and Business Systems Related Topics 4
J How to understand IATF 16949 Clause 8.5.2.1 - Traceability IATF 16949 - Automotive Quality Systems Standard 5
A Aluminum Die Casting Product Traceability Manufacturing and Related Processes 10
G Traceability - Checklist from NIST General Measurement Device and Calibration Topics 4
Raffy ISO 13485 NIST Traceability requirements for calibration of test equipment ISO 13485:2016 - Medical Device Quality Management Systems 3
G Traceability of laser based x-y measuring machine General Measurement Device and Calibration Topics 5
A Power Traceability certificate for values for voltage, current and phase General Measurement Device and Calibration Topics 1
Q Allowed no manuals, technical instructions traceability in products ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Is NIST traceability required if a Refractometer calibration is done in-house? Calibration Frequency (Interval) 6
M Component Lot Number Traceability - Class I reusable and "resposable" Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 10
B What is the FDA guidance regarding selling replacement parts and traceability? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
J Individual part traceability - ink/paint sprayer? IATF 16949 - Automotive Quality Systems Standard 4
A Active Implantable Medical Devices - Legal Traceability Requirements ISO 13485:2016 - Medical Device Quality Management Systems 7
M Establishing traceability from calibrated glassware to non calibrated ones General Measurement Device and Calibration Topics 5
M Traceability of Tissue Samples US Food and Drug Administration (FDA) 1
