mlee97
Re: Need advise on R chart with PpK of 17.85 for Ford
Some additional info..
The operators were instructed to take the samples from the samples run (324 pcs) spread out evenly. They numbered the parts as they sampled so they should be fairly close.
In production the surface finish is machined by a large drill that just spots the face. In the plant's history we have never had a general surface finish failure reach our customer in over 15 years of my history on any production lines. We only have special cause deep scratches, dings, or missing spot faces, never normal tool wear related rough finish on the aluminum.
Our Machining procedure requires a surface finish check on these parts every two hours, so despite other misgivings, the customer is protected from variance creep. However, If I don't get this resolved, we are bound to 100% test.
