Analyst (Lab Technician) validation in food laboratory
AS Nur
dear folks..
I am now working for Food laboratory.. and i want to make my lab be " competence lab"... our lab, analysis some parameters of food (protein, fat etc) and we use "accredited Method" such as kjedahl method for protein
but now i want to make "competence analys", and do you know how to validate lab analyst ? i 'll apreciated if you have excel template for that ...
Thanks for your valuable help...:thanx:
BradM
Re: Analyst validation in food lab.
Glad you dropped by in!
I realize English is a Second Language, but it is somewhat difficult to ascertain your question.
The best I can gather, you are going to work for a company that analyzes food, and you are looking for a validation method for the process. Is that correct?
Or are you wanting to perform some analysis of the technicians to demonstrate competency? What is your requirement/guideline for needing to verify competency?
Sorry if I am nowhere near your query. Please feel free to repost more information.
AS Nur
dear BradM...
thank for your quick replay.. sorry if my letter is not very clear for you...
.. Actually I want to validate competency of lab technician (analyst) but I dont have any procedure or guideline to do that...
True Position
Re: Analyst validation in food laboratory
This is usually done by documenting training and validation of training. If you have standard lab methods, has the person been trained to the process? Have they showed that they understand? Do you have training records?
Often a matrix of lab personnel and testing they have been trained to is used, occasionally color coded to a few different levels. (Competent and could train someone else, can work with minimal supervision, requires moderate supervision, no training)
AS Nur
dear hawat...
thanks for the replay...I already have lab std methods and training procedure and record.. i need to validate competence of analyst.. i heard in pharmaceutical industry, now i working in Food industry, they used statistical method to validate the competence of analyst.. usually they using Z score or RSD.. but i am not realy clear what the reason of that... Can some body give me a light to see more clear about that procedure or guideline?
mbulentcakar
Hi As Nur and all,
There may be many ways. Basically validation of analyst is done by evaluating his/her training records and experience (It would be lack of conscience to validate analysts only by a statistical method).
But how to validate an analyst for any method, say for kjeldahl method, depends on your conditions. You may run a repetability reproducibility study (maybe you've already done that for method validation) and appy ANOVA for different analysts. If no significant differences than you can validate all analysts. This is a practical approach for start up laboratories.
For a new analyst, you may have a validated analyst and the new analyst to run a series of analysis with the same sample and then use t-test for comparison of means.
A more practical way is comparing the variance of new analyst (by f-test) with the values in the method validation, just be sure the sample used in retest be in the same range with the sample used in validation study.
Hope this helps,
Bulent
AS Nur
dear Bulent...
Thanks for your replay .. so... what is the best method to validate analyst , Is Z score or RSD or anova???
FYI.. i'll Plan to validate analyst ones a years ....
mbulentcakar
I personally do not believe in 'best's and put my faith on 'fit for purpose'. If I were in your position I probably would run a yearly retest study for every test, probably for 6-10 repetitions starting from sample preparation and for technicians involved in that test. Then I would calculate %RSD (CV), means etc, which I would later incorporate with validation data and also I would update measurement uncertainty analysis.
But for validation I would run an ANOVA and then evaluate.
There's also another possibility if you're in any proficiency testing scheme. You can test the PT sample as usual and have other technicians also test the sample and evaluate after PT report.
Hope this helps.
Regards,
Bulent.
Basem
hello,
I think to prove the competence of technical staff in ur lab you can simply let them run a reference material periodically or a traceable in house reference material and compare there results to the actual results of them.
But if you are running a control chart for the test method you can examine the competence of all the items of the test process including the technical analyst.
Hope it helps
Q Passed ASQ Certified Quality Process Analyst Exam! What next? Professional Certifications and Degrees 7
R Material allowed in the ASQ CQPA (Certified Quality Process Analyst) Exam ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 2
A Recommendations for the CQPA (Certified Quality Process Analyst) Exam Professional Certifications and Degrees 3
B Business Process Analyst - Where to start and what actions to take ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Marc Threat analyst says medical devices can be hacked remotely Other Medical Device and Orthopedic Related Topics 6
R RAPS Certification Relevant to IT Business Analyst? Professional Certifications and Degrees 4
C Certified Quality Process Analyst vs. Certified Quality Improvement Associate Professional Certifications and Degrees 3
A Passed ASQ CQPA (Certified Quality Process Analyst) Exam! Professional Certifications and Degrees 21
Q QI Analyst - Is anyone is still using version 2.0.1? Statistical Analysis Tools, Techniques and SPC 0
H Looking for Career Advice - My title is Quality Analyst - Where from here? Career and Occupation Discussions 1
P Trying to automate analyses of data from production process using Quality Analyst Quality Assurance and Compliance Software Tools and Solutions 1
gard2372 No Quality Manager, Quality Engineer, Quality Analyst ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Govind CQPA (Certified Quality Process Analyst) - NEW ASQ Certification Professional Certifications and Degrees 18
E Analyst (Quality) - Does anyone have a job profile for an analyst? Document Control Systems, Procedures, Forms and Templates 8
F Environmental Requirements E-Lab General Measurement Device and Calibration Topics 0
R Calibration lab environmental monitoring General Measurement Device and Calibration Topics 4
I IATF Lab Scope Testing Qualification and Competency Documentation IATF 16949 - Automotive Quality Systems Standard 3
S Qualification question - ISO 13485 - Setting up a small lab Reliability Analysis - Predictions, Testing and Standards 2
H Can a calibration lab still use ISO 6789:2003 as guide for torque calibrations Other ISO and International Standards and European Regulations 1
F Position of Quality Manager - Can the organization's Quality Lead be shown as Quality Manager of the lab as well? ISO 17025 related Discussions 5
W My company is looking to start a materials testing lab that conforms to ISO17025:2017 ISO 17025 related Discussions 3
P Testing lab in India IEC 60601-2-25 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M Microbiological Testing Lab - Layout & Standards Other Medical Device Regulations World-Wide 0
D USFDA vs NRTL/IEC 17025 Differences - Compliance testing lab ISO 17025 related Discussions 0
D USFDA vs NRTL/IEC 17025 Differences - Compliance testing lab US Food and Drug Administration (FDA) 6
S How many of you are using Robotic process automation for calibration lab management? ISO 17025 related Discussions 0
C Must your reference standard provider be ISO17034 certified to meet your testing lab's ISO 17025 certification requirements? Other ISO and International Standards and European Regulations 2
S The procedure for replicate check in calibration lab as per ISO 17025 General Measurement Device and Calibration Topics 2
M Arguing with the test lab about failing in an EMC test IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
D Help identify a Nationally Recognized Testing Laboratory (NRTL) (UL) certified lab General Measurement Device and Calibration Topics 3
I FAR Part 43 and Application to 17025 Accredited Cal Lab Federal Aviation Administration (FAA) Standards and Requirements 2
S Is it mandatory for a Calibration Lab to be ISO 17025 accredited? General Measurement Device and Calibration Topics 7
G Setting Up a Basic Quality Lab for a small manufacturing company General Measurement Device and Calibration Topics 2
C MSA for Non Manufacturing - Design Validation, Characterization and Qualification Lab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D 7.6.3.2 External Lab - HELP!! IATF 16949 - Automotive Quality Systems Standard 5
J ISO 17025 testing laboratory - Receiving lab supplies - What really needs a C of A? ISO 17025 related Discussions 2
R (OOT) Measurement Equipment after the calibration at a third Party lab General Measurement Device and Calibration Topics 3
M Auditor has requested that the granite table in the lab be Calibrated Calibration and Metrology Software and Hardware 19
P Data Collection - R&D / Lab Notebooks Document Control Systems, Procedures, Forms and Templates 5
M How to perform Chelex DNA Method Verification in the lab General Measurement Device and Calibration Topics 2
G Temperature Requirements for a Manufacturing Inspection Lab General Measurement Device and Calibration Topics 5
S IEC 60601-1 Cl. 14 - Report changes in Software after Testing to Test Lab? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
G TS 16949 External Lab for Raw Material Certs for PPAPs IATF 16949 - Automotive Quality Systems Standard 26
Ron Rompen Seeking Test Lab which can do 1440 Hour Accelerated Weathering Characteristics Misc. Quality Assurance and Business Systems Related Topics 1
V Qualification & Management Of Contract Quality Control Lab - Formats & Templates US Food and Drug Administration (FDA) 0
S Does anyone use a FRACAS system to track lab equipment issues? Calibration and Metrology Software and Hardware 1
F Biocompatibility study conducted in the GLP lab outside Japan Japan Medical Device Regulations 2
