Sure I get that and as I’ve said I’m a big proponent of it. But there has been a lot of counter points about Boing not messing up and very little about the physics of the crack. Since detecting this type of failure is the point of stress testing of any product including aircraft, the next step to take is to understand the cause and then correct it.
Too often in my experience this “it happened under high stress” is a precursor to the rationale that it need not be corrected because it won’t happen under normal use.
If our defense of Boing at this time is to have any credibility we must also be crystal clear that the failure must be understood and corrected.
Remember that Boing did in fact know that the 737 max MCAS software would ‘over react’ to a single sensor that routinely fails adn they did nothing about it until hundreds of people died. Also the starliner was known to have a leak but obviously the investigation was shallow and did not catch let alone correct the failures before launching people into space. (And I will poke the bear by reminding everyone that the party line right now is that the leaks were OK because it was a test flight…).
Boing’s laser focus should be on determining the cause and fixing the problem. And sorry, but fair and balanced includes the fact that Boing has a recent history of several quality problems that they basically ignored. If we are going to be balanced then we need to say that the failure needs to be fixed as often as we defend Boing’s intentions and actions.
