Re: Corrective Actions getting to the root cause?
I used "standard" in its sense that's synonymous with "criterion."It is not a “standard”, it is a maximum allowable value.
The subject of operator error has been extensively discussed here. Have a look at Operator Error, System Error, or Both? (for example), so there's no point in doing it again here.The system owners want to take the easy way out and blame the operator when, in fact, the system failed the operator. The system did not provide for the proper tooling (do you have a left-handed operator operating a right-handed machine?), proper flow (if non-conforming material does not flow 180 degrees away from the conforming material flow path, it WILL find its way back into standard flow), adequate space, good lighting, etc. Basically, the operator cannot cause a failure. They can only point out weaknesses of the system. The 3% opportunity is to allow the system owners and management to lay some blame on the operator and, thereby, feel better.
That's not right. It's not even wrong.If the operator truly caused a failure, they had to do so purposefully. Follow Deming’s writings and fire them if necessary.
That's very impressive, but I must say that a product line that's scrapping >115,000 units a day seems like a pretty easy target. Nonetheless, if you were able to reduce operator error to next to nothing, that's great. You shouldn't project your own relatively narrow experiences (especially ones that are surely atypical) onto the world at large, though.P.S.: By following the above concept to identify product and tooling changes, a team reduced scrap rates of a product line that used 288,000 parts and assemblies per day from 40% to 0.05% in 3 months and achieve almost zero process failures (0.03 DPMO) within 12 months and making 55% EBIT.
